Old 02-17-2009, 03:06 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Another 3/4 ton question
I have 33 x 12.5 x 16.5 tires on aftermarket rims on my 72 C-20. I am going to look at some factory rims at a local yard that are both 16 and 16.5 Neither set are split rims (I have confirmed this) I am going to assume they are both 7" wide. Will either set fit my tires??? Obviously, the 16.5 would be first choice, but the 7" width is what concerns me the most. Thanks.
To add another question: If my current tires won't fit on the factory 7" wide rims, what is the largest tire I can go with? Thanks.
leddzepp is offline   Reply With Quote
Old 02-17-2009, 07:10 AM   #2
Re: Another 3/4 ton question
I`ve seen Joes Junk has a 4wd that he mounted 12.50/33s on factory 7" rims.I`m sure tire people will tell you that will cause a high crown in the tread surface.The stock 16s that came after spilt rims are narrower and I wouldn`t do it.The 16.5s jump down from 12.50 to 9.50.The 9.50s would be the recommended size.They dropped 10.50s off the radar.I think Coker has some bias ply for restoration jobs.
Old 02-17-2009, 08:52 AM   #3
69 camper custom
69 camper custom's Avatar
I have 31 x 10.50 x 16.5 tires on my truck and they are on 10" wide rims.
69 camper custom is offline   Reply With Quote
Old 02-17-2009, 10:02 AM   #4
Daks
I like crayons
Daks's Avatar
I replaced the old 16.5 inch rims with 16's as well and the largest tire the they would put on those rims (they are actually like 6 1/2 or 6 3/4 inch width I think they said) was a 285/75 R16. They measure just smaller than 33 inches. I was told anything larger could actually slip off the bear during something as simple as hitting an imperfection in the road such as a minor pot hole. Truth or not? I have no idea, just what I was told...
Daks is offline   Reply With Quote
Old 02-17-2009, 10:30 AM   #5
Joesjunk
Joesjunk's Avatar
I did put a set of 33x12.50x16.5 tires on 16.5x6.75 wide wheels. They actually fit and looked pretty good. The wider wheels are just so hard to find. A 285/75/16 tires on a GM 6.5" wide wheels works too. Ford vans have a 16x7 steel wheel and 285/75/16's look good on them too.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 02-17-2009, 10:52 AM   #6
tazztoy
my fav is a 255/85 r16 little narrower than the 285 but same height or a tade more. I still like the look of a narrower tire and less rolling resistance pushing them down the road.
'71 K-20 6.2, 5spd, 4x4, longhorn, FACTORY cab lights, project.
'07 cummins/6spd
'79 3500 454/400 4x4, dana 60,
'84 toy 4.6/700r4 cust lift, 35"a/t, welded r, locker f
'99 F250 7.3/zf6 spd reg/long, edge, local fab ext. (wifes)
'79 Bronco 351/c-6 13" w/44 ground hawgs (wifes)
tazztoy is offline   Reply With Quote
Old 02-17-2009, 03:09 PM   #7
OldCreek
OldCreek's Avatar
yep, a 255/85r16 will fit a 6.5 rim. It is roughly 33.4". The 285/75r16 is something like 32.5" (i think). I'm guessing the 285 will fit a 7" rim.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-17-2009, 04:00 PM   #8
snj8198
snj8198's Avatar
255/85 is what i run as well. the narrower tread creates a higher lb/sq inch factor which equates to a better slick road tire and as tazz stated less rolling resistance.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
