Old 02-17-2009, 09:49 PM   #1
shortbed70
shortbed70's Avatar
Cutting holes in X member?
I am going to be installing some rings in the rear x member for exhaust to go through BUT I don't have a plasma,oxy torch. Is there another way? I know I could use a hole saw but I would have to find a way to center it any other ideas.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-17-2009, 10:37 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Cutting holes in X member?
Hole saw through a 2 x 4 the size you want then screw or clamp it to the crossmember. This will keep the hole saw steady when you go through the crossmember without having to have a pilot hole in the center.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 02-17-2009, 11:09 PM   #3
Twisted Minis
Twisted Minis's Avatar
Do your hole saws not have a pilot bit to keep them centered?
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-17-2009, 11:15 PM   #4
SCOTI
SCOTI's Avatar
Good idea on the use of wood as your 'pilot' hole.
The c.member isn't solid where the pilot bit would need to be centered. Some guys weld a piece of strap across the c.member & drill a hole in that as their pilot hole (& keep things consistent).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-17-2009, 11:16 PM   #5
texastrendz
i used an air body saw for mine. it took a little time but was worth it since there was zero cleanup after and no heat involved.
texastrendz is offline   Reply With Quote
Old 02-17-2009, 11:34 PM   #6
shortbed70
shortbed70's Avatar
I never thought about the 2x4,HUH my dads a carpenter too... DUH. Thanks. I'll get some pics of the process this weekend.
Troy
Big Red Dog build
Old 02-17-2009, 11:41 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Ive used that trick a couple times and it works well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-17-2009, 11:55 PM   #8
68 short step
i did this too, it turned out good...
68 short step is offline   Reply With Quote
Old 02-18-2009, 09:38 AM   #9
Ram-Man
Ram-Man's Avatar
This works well when you already have a hole and want to hole saw it larger.
Old 02-18-2009, 09:45 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Great idea. On smaller holes, I have always used a wood rod as a filler. I guess it helps that I alwys have a surplus of broken pool sticks available.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
