67 K20 disc brake conversion?
what's involved in converting my 67 K20 to front disc brakes?
1967 K20 Stepside Longbed 250-6 sm420 |
Re: 67 K20 disc brake conversion?
I did it to my 68 K-10...
You need a 3/4 ton axle from any chevy up to 88ish??? new rubber brake lines, new MC and prop valve (might as well get a full kitwith booster,bracket,MC and prop valve), might as well go power steering from donor truck too... gearbox, drag link, PS pump and lines. Of course you need to match the gearing for the rear... Your frame is flat behind the steering box which causes more issues (I have an adapter that I bought).... Not quite a simple bolt on but in the end you could have a PS,PB disc truck for about $750
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 02-17-2009 at 10:54 PM. |
i think blackbirds has a kit which is $$, and you are still stuck with the smaller ujoints and larger turning radius of the old axle.
I agree with what msgross said. The easiest way, imo, is to upgrade to a newer axle with discs.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
