Old 02-17-2009, 11:17 PM   #1
pete29
is my distributor vaccum port timed or full
I have a 72 chevy 3/4 ton with 350 and hei distributor from summit. I'm tryin to put a edelbrock carb on it but not sure if the vaccum port is timed or full. Anybody Know?
pete29 is offline   Reply With Quote
Old 02-17-2009, 11:45 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: is my distributor vaccum port timed or full
I assume what you are referring to is "ported" versus "full vacuum." If that's the case, then look at the carburetor where the butterfly shafts is. Normally below that area or base of the carburetor is full vacuum and above it is ported.
Not sure about Edlelbrocks but that's the way quadrajets, Rochesters are.
68gmsee is offline   Reply With Quote
Old 02-17-2009, 11:46 PM   #3
Indyuke
Most likely ported. They stopped using full vacuum in the fifties and sixties, I think. Someone else will chime in to say for sure.
Oops! Didn't read the original post fully. If you have it on the truck, you could always put a vac gauge on it while the truck is running.
Indyuke is offline   Reply With Quote
Old 02-18-2009, 12:51 AM   #4
Rollie396
someday it will be done!
Rollie396's Avatar
Looking at the front of the carb,the left hand port (above the throttle plate) is ported and the one you want.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 02-21-2009, 05:11 AM   #5
jk396
i was wondering how to get a complete engine vacuum routing for a 72 402 and a 72 350 both automatics,the assembly manual i have does not show any specifics
jk396 is offline   Reply With Quote
Old 02-21-2009, 01:46 PM   #6
LONGHAIR
You really need to check the specs of the distributor....and how it was intended to be run. Stock specs of the truck and/or carburetor are totally meaningless.
"Ported/timed" vacuum is a crude emissions gimmick from the late '70 and early '80s. The distributors were calibrated differently to be used that way. The points type distributors from before that, and most of the aftermarket units are made to be run with full vacuum. Why the heck those carburetor companies think that they can tell you how to run your vacuum advance is totally beyond me. They don't know what you have, and it makes absolutely no difference to the carburetor at all.
I would stay away from ported vacuum and any distributor that is intended to run that way. It is not good for anything and is actually leaving both performance and fuel economy on the table. While you may or may not notice it on the water temp gauge, it will definately make your engine run hotter in the exhaust phase. Manifolds, head pipes, and underhood temperatures will go up quite a bit. This is/was an intended effect that burns up some of the un-burned hydrocarbons in the exhaust. It is essentially "late" timing at low engine RPM because the vacuum advance is not activated.
However, there is more centrifugal advance built into these distributors to "compensate" for this at higher RPM, so you can't just switch it to a full vacuum source.....or you end up with too much total timing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-21-2009, 10:19 PM   #7
spinning wheels
spinning wheels's Avatar
Longhair, so would a stock GM HEI from the late 70s early 80s be a ported vacuum dist.?
Just curious, as I was going to drop an HEI from a '75/76 GMC 1 ton, into my 3/4 ton '72 truck. Currently I am running a points dist. with Pertronix module and a MSD blaster 2 coil. My carb is a Edelbrock 1406, with a stock turbo 350.
Any advice would be appreciated.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-21-2009, 10:57 PM   #8
jk396
Thumbs up Re: is my distributor vaccum port timed or full
thanks so much for the info.
