12-12-2002, 08:43 PM | #1 |
THE QUICKER FIXERUPER
Shavin
I am going to shave the door handles on my 69 panel. I am either going to use an autoloc kit, or I saw a web site that made a direct bolt on kit for our trucks but I cant remember where I saw it. I have seen pepole cut out the handle area and weld in new material, and allso just make a patch for the dimple. What have you guys done, any advice would be apriciated.
12-12-2002, 08:46 PM | #2 |
Seņor Member
Patch over the dimple. The bend in the stock skin adds a little bit of strength to that otherwise wide open space.
Kenneth
12-12-2002, 09:18 PM | #3 |
That is what I am going to do.
p.s. What happend to the new avatar??? |
12-12-2002, 09:47 PM | #4 |
Got big-block?
Don't go with AutoLoc, go with ShaveTech instead. Developed by a board member. Here's his website:
http://www.customclassic.com/
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
12-12-2002, 10:36 PM | #5 |
Thanks super chevy that is the site I was looking for.
12-12-2002, 11:18 PM | #6 |
Has anybody ever used or heard of somebody using the shave tech kit. Im kinda skeptical.
12-13-2002, 12:54 AM | #7 |
i just put a patch over the holes. i used a p.a.w kit from summit..it comes with 15# selenoids but i upgraded to 45#. so fars its been a good kit. costs me 200 bucks.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
12-14-2002, 01:14 AM | #8 |
Flamin' Bass
I started to cut out the small patch pieces, then saw a web page that showed it being done with a single rectangular piece (+ the lock hole patch). Sooooo.... I cut out the whole door handle area and tacked in a single patch.
I was using a brand new Goodmark door and after tacking around once or twice (lowest heat, .023 wire, C25), waiting for cool down each pass, I thought things were OK. Five minutes later, I heard a thump and saw a 6" diameter, 1/2" deep 'crater' just below the patch. I ended up trying to fix this and had to use filler/heat/blood, sweat and tears on about half the door, and it still doesn't look right. Not wanting to make the same mistake, (whatever mistake it was), I used a hunk of 1/4" as a heat sink on the second door and the results were much better!
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
12-14-2002, 10:28 AM | #9 |
I just welded over the depressions in the door because anywhere there's a body line will be less prone to warpage.
12-14-2002, 04:20 PM | #10 |
Thanks guys, what brand of actuator kit did you guys use?
12-14-2002, 04:29 PM | #11 | |
Seņor Member
This gives me the additional throw I need to pop the door latch and it keeps the motor and assembly away from the window regulator. Kenneth
