02-18-2009, 01:38 AM | #1 |
rear disc brake kit
Anybody have a rear disc brake kit that they like? I'm not looking to spend thousands, just mainly tired of looking at drums behind 20" wheels. I would like something that wouldn't require changing the fronts out right away in order to not look weird. Help me out.
02-18-2009, 01:43 AM | #2 |
Re: rear disc brake kit
subscribing, like to hear what others have done or plan to do...
theres a thread about the caprice disc set up on here w/ f body calipers but we need a template for the caliper bracket so someone can make them.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 02-18-2009 at 01:46 AM. |
02-18-2009, 01:53 AM | #3 |
I've heard of the Impala SS/Caprice 9c1 brake swap, that needs a custom bracket, but then I found this:
http://67-72chevytrucks.com/vboard/s....php?p=2988690 Gotta love GM interchangeability!
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
02-18-2009, 03:19 AM | #4 |
BAD BOW-Silverado XST
Swap in a Lincoln or Caddy 5X5 rear end. Easy disc conversion!
02-18-2009, 04:16 AM | #5 |
02-18-2009, 09:24 AM | #6 |
WILWOOD DISC BRAKE KIT: #140-4545-B ..... Summit $486.95
02-18-2009, 09:59 AM | #7 |
It followed me home?
Here is a link to the kit that TVBLAZER78 used
http://67-72chevytrucks.com/vboard/s...highlight=rear
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-18-2009 at 10:07 AM. |
02-18-2009, 10:05 AM | #8 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I think the one Travis used on his Blazer is the ticket.....cant beat it for the money!
02-18-2009, 10:15 AM | #9 |
Low & Fast!
Yep I like it...
02-18-2009, 12:04 PM | #10 |
02-18-2009, 12:25 PM | #11 |
02-18-2009, 12:56 PM | #12 |
From the emails I have sent to Blackbirds, they say the only non-GM part is the custom bracket, so calipers, rotors, and pads should be easily available, not a custom part.
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
02-18-2009, 01:08 PM | #13 |
Low & Fast!
He only uses GM parts, the calipers are the same size as your front ones on your truck and so are the pad. Same PN and everything..
02-18-2009, 01:29 PM | #14 |
From what I understood, the bracket was custom, non-gm. Is this correct or did I misunderstand?
02-18-2009, 01:35 PM | #15 |
Superbad
* 95 Dodge 1/2 ton 4X4 front rotors redrilled to 5x5" lug partern $33.99 X 2 = $67.98 : http://www.partsamerica.com/ProductD...pe=221&PTSet=A
* Speedway Motors weld on caliper brackets $9.99 X 2 = $19.98 : http://www.speedwaymotors.com/1969-1...CKET,3348.html * 73 Chevrolet C10 right front caliper $14.99 : http://www.partsamerica.com/ProductD...e=5003&PTSet=A * 73 Chevrolet C10 left front caliper $14.99 : http://www.partsamerica.com/ProductD...e=5003&PTSet=A * 73 Chevrolet C10 front caliper pads $16.99 : http://www.partsamerica.com/ProductD...pe=219&PTSet=A * 73 Chevrolet C10 right front caliper hose $19.99 : http://www.partsamerica.com/ProductD...pe=228&PTSet=A * 73 Chevrolet C10 left front caliper hose $22.99 : http://www.partsamerica.com/ProductD...pe=228&PTSet=A Total $177.91 I have pictures on my computer at home, looks almost like it would have came from the factory with them. I did not set it up with a parking brake because my Suburban will be bagged & laying frame, it won't need it. Speedway Motors also sells complete weld on rear disc brake kits. Without parking brake: http://www.speedwaymotors.com/GM-COM...PACE,2000.html With parking brake: http://www.speedwaymotors.com/Speedw...rake,1999.html |
02-18-2009, 01:36 PM | #16 |
Garage wrench
It looks to be the best to me too.......I may have to look into that
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
02-18-2009, 02:01 PM | #17 |
69fatmotor
http://store.summitracing.com/partde...BK1325&FROM=MG here's some from summit racing
02-18-2009, 02:15 PM | #18 | |
02-18-2009, 02:40 PM | #19 |
Low & Fast!
Yes the bracket is custom, that is the only part..
02-19-2009, 01:43 PM | #20 |
Superbad
Pic of my rear disc brakes. The Suburban stops on a dime now, brakes are much more responsive.
02-19-2009, 04:02 PM | #21 |
Living Legend
I may have missed this somewhere but i have all the front disk parts (calipers pads rotars ect) to use for the rear disk setup on an 81... is there anywhere to buy just the bracket? is that all i need.... sorry im a bit confused when it comes to brakes can i go that rout without changing the track width? angain sorry if the questions have been answered already..
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony |
02-20-2009, 05:14 PM | #22 | |
Evan B. |
02-20-2009, 07:22 PM | #23 |
im confused
02-20-2009, 07:40 PM | #24 |
Just Cruizin
Does anyone that has used a kit have a template of this custom bracket? with the specs? I know a good machinist and would like to give him the specs to see how hard it would be to do. That way I could just get the other parts from the parts store and save some $$$. Thanks
02-20-2009, 07:45 PM | #25 | |
Living Legend
