02-18-2009, 12:52 PM | #1 |
Active Member
Differences in 72 4x4 swb frame and 67 gmc 2wd swb frame?
I have a rusted out 72 4x4 frame and found a 1967 2wd gmc frame with rear leaf springs. What would be the difference besides the front end? Easy swap or not? Thanks
_________________________________ 1972 Chevy SWB 4x4 350 4speed |
02-18-2009, 01:10 PM | #2 |
resident oilfield trash
Re: Differences in 72 4x4 swb frame and 67 gmc 2wd swb frame?
Wont be to bad if you can fab the brackets you need
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
02-19-2009, 03:53 PM | #3 |
Yes,it`s all doable,as long as all the 4wd specific stuff is usable.You need the motor & transfer case crossmembers.The frame tapers in on a 4wd,so the springs set outward on the axles more on the 2wd.If you`re using the rear from the 4wd the leaf saddles will need relocated.`67s don`t have a dimpled rame to mount a`68-up power steering box.You need to space the box off the frame or dimple the frame.
03-18-2009, 05:02 PM | #4 |
Active Member
Attaching Front Leaf Springs. I noticed on the 67 frame I picked up the frame isn't flat where the back shackel on the front leaf spring would attach what would you do to fix this problem? Weld in a plate?
03-18-2009, 10:50 PM | #5 |
Active Member
Heat it, flatten it, drill the hole for the shackle; I put a small plate on the outside of mine.
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
