02-18-2009, 01:05 PM | #1 |
American Autowire Update wire harness kits finally here!!!
Currently these only fit 69-72 trucks, Blazers, Suburbans. Will also work with GMC's as well. Just released this week and should start shipping week of Feb 23. These list for $539, we will be selling them for $485, over $50 off list! I have already listed these in our store and we are ready to take orders for them. Here is a run down of their features:
1. Replacement headlight switch with internal 30amp circuit breaker included. Retention collar nut, adjustable length shaft, and custom knob are also included. 2. Standard turn signal flasher, hazard flasher mounted on fuse panel, and horn relay mounted on harness. 3. Fuse box designed to fit in original location. All required hardware supplied. New ATO fuse panel allows for easy fuse and circuit breaker accessibility. Harness is laid out and formed to allow for nearly all after market accessories such as; gauge packages, wiper systems, heat and air conditioning systems, etc. 4. Original switch connector bodies! (Exclusive to American Autowire) 5. Steering column connectors will plug directly into most after market steering columns as well as 1969-72 GM columns, which utilize stock GM turn signal switches. 6. Along with wiring for your original dome/interior lighting we have included separate under dash light sockets. 7. Instrument Cluster wiring is designed with a cluster harness disconnect system for easy service and assembly. All original terminals, connectors (exclusively from American Autowire), and light sockets are also supplied for original cluster gauges. However, the best aspect of the disconnect system is that any gauge cluster package can be easily and neatly wired in. This includes AUTOMETER, CLASSIC INSTRUMENTS, DAKOTA DIGITAL, STEWART WARNER, and VDO just to name a few. 8. Rear body harness assembly is designed to plug into the main harness in the original location. Flexibility in harness design allows for original or custom routing. EXCLUSIVE! Rear body wiring includes backup light lead wires with rubber connectors, stop and tail light lead wires with correct light sockets and boot / tube assemblies for Fleetside trucks, or correct connections and terminals to mate with the tail lamp assemblies for Stepside trucks, license plate connection wire, side marker lead and ground wires with lamp sockets, and fuel tank sender wire and connection. 9. New floor dimmer switch is provided with extra long mounting screws for ease of installation. Wire length and connection accommodate original floor mount dimmer switch. 10. EXCLUSIVE! GM bulkhead connectors for the engine and front light wiring are included and ready for easy installation. Original or custom routing of the new harness is no problem! 11. Engine wiring includes connectors for original points type as well as H.E.I. distributors. Power and tach connectors supplied for GM H.E.I. distributors. Alternator connectors are supplied for GM SI series internally regulated alternators. GM CS series alternator adapter is available separately. 12. Front lighting includes extra long leads for special routing when custom under hood appearance is desired. All headlight, park light and directional light connectors and terminals are provided, as well as a switched trigger wire for electric fan relay (usually recommended with AC). You�ll find that with our inclusion of all the original style light sockets, connectors, terminals, etc. packed into every aspect of this harness, it makes it the most complete system of it�s type in the industry!
Mike Redpath |
02-18-2009, 01:09 PM | #2 |
BlahBlahBlah
Re: American Autowire Update wire harness kits finally here!!!
This sounds great. Are they in stock ready to ship?
02-18-2009, 01:12 PM | #3 |
They will be shipping next week.
Mike Redpath |
02-18-2009, 01:14 PM | #4 |
BlahBlahBlah
LOL...I got all excited and failed to notice you had already posted that in the text...sorry =)
02-18-2009, 03:01 PM | #5 |
Do these replace the stock harness or just update it
70 SWB STEPSIDE 70 BLAZER 09 challenger |
02-18-2009, 04:41 PM | #6 |
They replace the wiring 100% with the exception if you have stock A/C, you will still need an A/C harness
Mike Redpath |
02-18-2009, 07:05 PM | #7 |
Self Made Hundredaire
hmmmm. I really can't decide which harness to buy now.
'79 corvette - all original 49k car! '03 Z71 ECSB - gas hog '57 Belair 2 door hardtop. Love of my life! |
02-18-2009, 07:09 PM | #8 |
Looks like a great product!!
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
02-18-2009, 07:32 PM | #9 |
That should have been your problem before the release of this kit. No other kit can compare, period.
Mike Redpath |
02-18-2009, 07:38 PM | #10 |
Tasty Cakes!
What's the difference between a 69-72 harness and a 67/68? I was under the impression they were the same.
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
02-18-2009, 07:48 PM | #11 | |
Thanks!
02-18-2009, 07:54 PM | #12 |
I'm interested too but not sure I'm up for the task.
Any installation instructions to take a look at? How long for a non pro to install? (I'm better electrical than mechanical) How long/much would you think to have shop do it for me? Thanks! |
02-18-2009, 09:49 PM | #13 |
Tasty Cakes!
Correct me if I'm wrong, but I believe this kit is supposed to be almost plug and play. That is the point of their "Update" kits. Using factory plugs while adding modern conveniences that weren't available at the time.
And AAW is known to have excellent customer service.
02-18-2009, 11:15 PM | #14 |
Main difference is the column plug is different. I need to call and find out any other differences there may be and why they could not be used in a 67-8
Mike Redpath |
02-18-2009, 11:18 PM | #15 | |
Mike Redpath |
02-18-2009, 11:21 PM | #16 |
I can probably get you a set. Figure 2 good weekends for you to do it yourself. Shop install will greatly vary with how much disassembly or assembly they have to do. A good shop that only has to do the wiring in a truck, no extras should not take more than a couple days. Cost will vary upon where you live.
Mike Redpath |
02-18-2009, 11:30 PM | #17 | |
Mike Redpath |
02-18-2009, 11:44 PM | #18 |
Ive used an american auto wire kit before.It was on ny 55 chevy bel air and also was one of the factory fit kits.I must say It was realy nice and fit perfect.It came with good instructions plus every wire was labeled for its porpouse.
Im definatly getting one of these kits when I get to it. |
02-18-2009, 11:48 PM | #19 |
I will be getting one of these for sure. Much sooner then later too.
00' Z28 ("wifes" car) 92' Mustang w/sbc everything needs a little heart beat 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
02-19-2009, 12:13 AM | #20 |
is that 485 just a temporary price when does it end and sorry if this been asked just to clarify this is a complete kit all conectors and all will it work with dolphin gauges
02-19-2009, 01:27 AM | #21 |
that is our everyday price, complete kit, yes will work with aftermarket guages
Mike Redpath |
02-19-2009, 11:39 AM | #22 |
I'm going to buy this kit once I get paint...
Also wondered why 67/68 weren't included.. Didn't the fuse box change oreintaiton (horizontal vs vertical) and no side marker lights needed. This is the best setup i've seen for the price.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-19-2009, 12:39 PM | #23 | |
Junior Member
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-19-2009, 02:01 PM | #24 |
Side marker lights were available in 68, and base 69 did not have them. AAW told me the 67-8 handbrake interfered with the dash harness somehow. Not sure of that one. I have a 68 and 69 at home so I am going to research that further.
Mike Redpath |
02-19-2009, 02:06 PM | #25 |
$50/hr, roughly 2 days. If you drove up and helped take it apart and put it back together would reduce costs.
Mike Redpath Last edited by Musclerodz; 02-19-2009 at 02:08 PM. |
