Old 02-18-2009, 01:11 PM   #1
Musclerodz
AAW Update harnesses finally available!
The for sale thread with the details is listed in the for sale section. AAW has finally released their Classic Update kit for 69-72 Chevy/GMC trucks. 67-68 soon to follow. You can order from our website or give us a call. AAW harnesses are the most complete kit on the market and no other wire harness kit currently available can match:
1. Replacement headlight switch with internal 30amp circuit breaker included. Retention collar nut, adjustable length shaft, and custom knob are also included.
2. Standard turn signal flasher, hazard flasher mounted on fuse panel, and horn relay mounted on harness.
3. Fuse box designed to fit in original location. All required hardware supplied. New ATO fuse panel allows for easy fuse and circuit breaker accessibility. Harness is laid out and formed to allow for nearly all after market accessories such as; gauge packages, wiper systems, heat and air conditioning systems, etc.
4. Original switch connector bodies! (Exclusive to American Autowire)
5. Steering column connectors will plug directly into most after market
steering columns as well as 1969-72 GM columns, which utilize stock GM turn signal switches.
6. Along with wiring for your original dome/interior lighting we have included separate under dash light sockets.
7. Instrument Cluster wiring is designed with a “cluster harness disconnect” system for easy service and assembly. All original terminals, connectors (exclusively from American Autowire), and light sockets are also supplied for original cluster gauges. However, the best aspect of the disconnect system is that any gauge cluster package can be easily and neatly wired in. This includes AUTOMETER, CLASSIC INSTRUMENTS, DAKOTA DIGITAL, STEWART WARNER, and VDO just to name a few.
8. Rear body harness assembly is designed to plug into the main harness in the original location. Flexibility in harness design allows for original or custom routing. EXCLUSIVE! Rear body wiring includes backup light lead wires with rubber connectors, stop and tail light lead wires with correct light sockets and boot / tube assemblies for Fleetside trucks, or correct connections and terminals to mate with the tail lamp assemblies for Stepside trucks, license plate connection wire, side marker lead and ground wires with lamp sockets, and fuel tank sender wire and connection.
9. New floor dimmer switch is provided with extra long mounting screws for ease of installation. Wire length and connection accommodate original floor mount dimmer switch.
10. EXCLUSIVE! GM bulkhead connectors for the engine and front light wiring are included and ready for easy installation. Original or custom routing of the new harness is no problem!
11. Engine wiring includes connectors for original points type as well as H.E.I. distributors. Power and tach connectors supplied for GM H.E.I. distributors. Alternator connectors are supplied for GM “SI” series internally regulated alternators. GM “CS” series alternator adapter is available separately.
12. Front lighting includes extra long leads for special routing when custom under hood appearance is desired. All headlight, park light and directional light connectors and terminals are provided, as well as a switched trigger wire for electric fan relay (usually recommended with AC).
You�ll find that with our inclusion of all the original style light sockets, connectors, terminals, etc. packed into every aspect of this harness, it makes it the most complete system of it�s type in the industry!
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 02-18-2009, 01:51 PM   #2
rlm316
rlm316's Avatar
Re: AAW Update harnesses finally available!
What is the price?
rlm316 is offline   Reply With Quote
Old 02-18-2009, 02:02 PM   #3
Musclerodz
look in the for sale section
Mike Redpath
Old 02-18-2009, 02:20 PM   #4
OldCreek
OldCreek's Avatar
Is the front headlight wiring capable of running the high output lighting without melting down?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-18-2009, 03:00 PM   #5
Musclerodz
You still need to run a relay kit if you wish to run H4 or 9007 lights. Although the wiring is much better and would not fail, the switch is stil original type and still needs protected.
Mike Redpath
