PITbut
Can someone tell me whats this is from?
What is this from, and how do i prevent it? I sandblasted my cab, cleaned it, and epoxyied the cab. The cab sits in the garage. I did some metal work after that, and about 3/4 months later i notice this.
![]() That area is the left kickpanel. Thats where the floor meets the kickpanel. Only thing i can think is that its metal shavings that have rusted... I obviously cant paint over that right??? How do i prevent this? I thought epoxy didnt rust... There was NO moisture at all except for regular air moisture in a garage... |
Rods
![]() Join Date: Nov 2002
Re: Can someone tell me whats this is from?
Well if you did any grinding the flakes can embed in paint or even glass and start to rust....also are you sure you coated the corners well enough
My guess would be it sat too long after sandblasting before it got primer on it or if you primed it right away maybe you didnt get that area covered good with primer and humidity set in to cause the rust on the raw metal.
how did you clean the cab after blasting?
![]() Join Date: Nov 2004
Is that old sealant or new?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
If your metalwork involved grinding, the grinding disc heats up the metal fragments which become hot, flying particles. The hot particles then come in contact with the epoxy primer and some are hot enough to melt their way through the primer and come in contact with the metal base. Some are just loose metal particles that rust.
If it were me, I would just scuff it and shoot it when ready. As long as you don't leave it exposed to the elements, it will be ok till you do so. Always take the time to blow off surfaces once you grind anywhere around them. |
#7 | ||
PITbut
***Ram-Man Re: My guess would be it sat too long after sandblasting before it got primer on it or if you primed it right away maybe you didnt get that area covered good with primer and humidity set in to cause the rust on the raw metal. ***
It did sit for quite a while inside the garage. THere wasnt any rust really but there was some light browning in that area. I just cleaned that up and coated over it.... It was only in one section of the cab. Is that where i messed up??? Quote:
wax.grease remover, air. Just whateve rit took to get rid of the dirt. Its new epoxy. DP Quote:
Thats fairly common in a crowded shop. Like stated above. We had a client refuse delivery on a S/Stl heat exchanger cause they said it was rusting and would not let it be unloaded. All it was grinding residue that rusted off another piece of equipment made from carbon steel that was close by before it was shipped. it was easy to take off but they should not have shipped it that way. Thats what it looks like to me from the pics.
i find that when blasting with sand it is necessary to clean and scuff with something like rolac wheels or at the very least a scotchbrite pad to remove imbedded blasting media particles from the metal// wiping down with solvent soaked rags is not enough
#10 | |
PITbut
Im just going to wire wheel it down, grind it, clean it with some acid, rinse it off, then reepoxy over that particular area... Any other suggestions? |
I was referring to the seam sealer. My bad. You need to remove the seam sealer, get behind it, coat it good, and put new seam sealer there.
#12 | |
PITbut
Im going to redo that area, no biggie.. I need to spray the cab, so i will just redo those sections and respray it... |
