02-18-2009, 08:06 PM | #1 |
accepting donations
Had an idea
When I bag my 68 I plan on using a c-notch. This should mean my pumpkin will hit the bed before my axle hits the notch, right?
How about cutting a hole in the bed for the pumpkin to fit through but use the piece of metal you cut out, weld on a hinge and put it back on the hole. That way the bed looks solid when at ride height but when slammed the pumpkin can hit that patch and just lift it up. Any thoughts on this??
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
02-18-2009, 10:59 PM | #2 |
Gearhead
Re: Had an idea
Sounds like it could work to me, hadnt ever really thought about that. I would think you just need a lip or a few tabs to hold the piece at bed floor level when its not being pushed up. Also might have to put something on the axle to push it up and not catch the brakeline or axle breather on anything. Sounds cool to me....
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
02-18-2009, 11:09 PM | #3 |
Re: Had an idea
If you choose to do this, I would put some kind of rubber insulation underneath it. I think it would rattle while driving, and that really drives me nuts.
If you can find it cheaper, I can fix it! |
02-19-2009, 12:07 AM | #4 |
Happy to be here
Re: Had an idea
It depends on the size of your notch. With a mild notch and bump stops your pumpkin won't hit the bed.
02-19-2009, 03:12 AM | #5 |
It'd be alot cooler if you did
Re: Had an idea
but I think it would work just fine...
02-19-2009, 03:53 AM | #6 |
Commander Taco Bello
Re: Had an idea
not a bad idea at all. Even the wood bed guys could do something like this if they really wanted.
02-19-2009, 07:35 AM | #7 |
accepting donations
Re: Had an idea
I figured I would add some sort of reinforcement underneath to prevent the patch from collapsing when there is something in the bed. I'm just knocking around ideas to try and get the truck as low as possible without major mods.
02-19-2009, 09:15 AM | #8 |
Happy to be here
Re: Had an idea
As a point of reference, the bed is not cut on this truck.
02-19-2009, 09:43 AM | #9 |
accepting donations
Re: Had an idea
Yeah someone has showed me that truck before. Looks awesome.
02-19-2009, 12:08 PM | #10 |
Re: Had an idea
Great idea Bro... With the right tweaking it would be pretty bad a$$... I would use the thinest cutting tool possible so the gap was tight when closed..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
02-19-2009, 01:02 PM | #11 |
accepting donations
Re: Had an idea
Well someone is going to have to try it before me. Its going to be a LONG time until I'm bagged.
02-19-2009, 01:18 PM | #12 |
Re: Had an idea
It'll be a month of two, but when i get around to replacing my bed floor i might just do this.
I agree with using the thinnest blade possible. |
02-19-2009, 02:08 PM | #13 |
accepting donations
Re: Had an idea
I look forward to pictures
02-19-2009, 04:22 PM | #14 |
Re: Had an idea
Use magnets to keep the hinged panel secured when you're going down the road. You can find a strong magnet that will hold the panel, but release when the center section comes up through it.
02-19-2009, 05:18 PM | #15 |
accepting donations
Re: Had an idea
Good idea.
02-19-2009, 07:39 PM | #16 |
Re: Had an idea
spring loaded like fuel doors
1969 Chevy C-10 350/700r4 |
02-19-2009, 08:49 PM | #17 |
Grandpa in the rustmobile...
Re: Had an idea
boy lol put a good idea up its gets 10x better wtih every post lol yall good thinkers
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-20-2009, 02:31 AM | #18 |
Re: Had an idea
How many times can you post that D*&% truck? I love that thing, and I get more pissed everytime I see it that mines not even close to being drivable, much less done...
Thats it, I'm headed to Texas,... just to drool on that thing and get it out of my system.... By far my fav truck..... .... now,... back to your regularly scheduled program............... .
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 02-20-2009 at 02:32 AM. |
02-20-2009, 08:18 AM | #19 |
Member of the longbed union.
Re: Had an idea
It's a good Idea if you dont plan to lay real close to the ground. I've seen it done before, gives the bed a clean look when at ride hight. But think about how far down you want to go down. It's a good Idea to have some type of bumpstop in your C-notch.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
02-20-2009, 09:00 AM | #20 |
Re: Had an idea
thought I would build you a flip up lid with Photo-shop as I had the same idea!
I will post it here when it done.
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
02-20-2009, 09:01 AM | #21 |
accepting donations
Re: Had an idea
Right on.
02-20-2009, 10:32 AM | #22 |
Re: Had an idea
Eather metal painted or plexaglass henged at bottom neion light for plexaglass
by the way how much notch requires hole in bed on stepside bed?
02-20-2009, 09:38 PM | #23 |
Re: Had an idea
Thread title should be "THE PUMPKIN PATCH"
02-20-2009, 10:30 PM | #24 |
Re: Had an idea
if you're only gonna do a bolt in C notch then there is no need to cut the bed floor.
02-20-2009, 10:37 PM | #25 | |
Re: Had an idea
Now, someone with a steel bed may not have an issue as wood is thicker. Also, I'm running no bump stops. If a person ran even a 1" bump stop, they would probably be fine. |
