02-18-2009, 09:15 PM | #1 |
help need a pic of heater switch plug
need a pic of heater switch plug I'm cleaning up my wiring and can not find the plug that goes to the switch
02-18-2009, 10:04 PM | #2 |
Active Member
Re: help need a pic of heater switch plug
02-18-2009, 10:06 PM | #3 |
so is 14 a Exeter plug u have to have
02-18-2009, 10:28 PM | #4 |
Active Member
Here's what mine looks like. I ran outside and took a pic of it. No A/C.
02-18-2009, 10:42 PM | #5 |
Active Member
If you need the cable and connector, this is on Classic Parts catalog.
http://www.classicparts.com/1967-72-...info/52%2D721/ |
02-18-2009, 11:00 PM | #6 |
ya i have that same plug 2 side by side and 2 on top of each other but it will not fit
02-18-2009, 11:01 PM | #7 |
02-19-2009, 12:02 AM | #8 |
Active Member
That seems to be the wrong connector for the switch. If you look close at mine you can see that the two wires on top are on top of each other like your switch connectors-not side by side.
02-19-2009, 06:21 AM | #9 |
lol but it all came off this truck like 6 years ago any ideas
02-19-2009, 02:00 PM | #10 |
Active Member
Had me going there... That's the connector that goes to the rear tail lights.
On the firewall in front of the heater connector should be a round rubber connector that goes through the firewall to the engine compartment and back to the tail lights. Not sure what happened to your other connector unless it's wrapped up there somewhere. Maybe someone cut it off??? Check the color wires on mine and see if you can find those in your truck. |
02-20-2009, 01:55 AM | #11 |
that plug is indeed from the tail light plug and the one pic by 68 gmcee is the correct plug cause i pulled my heaterbox out and the wire harness also took alook at it same as 68. there should be one wire thats on the fire wall passenger side that hooks up to the blower follow that wire it should lead you to the correct ones cause they are intact in the same harness.
02-20-2009, 06:48 AM | #12 |
cool thanks alot guys i have no idea where it is
