Old 02-18-2009, 11:31 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Compressor recommendations.
Please post pro's and con's and quality and specs and so on of 12v compressors. I currently have a Viair comp. but don't know the #. The truck is 100 miles away in storage, and will be purchasing another one. What should I look for? Do I want 100% duty cycle? What about warranty and longevity? Like I said I have 1 Viair comp. and one 5 gallon tank and will be adding another comp. and another 5 gallon tank, and I run 1/2" line and RE7's on my 72 GMC. What do you guys recommend?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-19-2009, 12:05 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Compressor recommendations.
Originally Posted by chevydog66 View Post
....and I run 1/2" line and RE7's on my 72 GMC. What do you guys recommend?
It sounds like you are on the right track with the exception being the 1/2" line. Unless you want a really fast system for clowning, there isn't a need for the more expensive 1/2 line and fitting required. I suggest 3/8" line, while some feel 1/4 is large enough. Consider your needs, but don't assume you need 1/2".
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-22-2009, 07:29 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I already have the 1/2" valves and line, so I'm stuck with it and I kinda like em. I am just wanting some recommendations for a compressor. THX
Old 02-22-2009, 07:59 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I would look into an engine driven compressor and add another tank. You'll be much happier that way. Lots of people are piecing together all the parts and putting together their own kits. You could also keep the existing electric comp for back up in case the truck won't start and run the compressor. Making your own bracket isn't all that hard, either.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-22-2009, 08:10 PM   #5
tds
Thanks for not answering his questions guys .
As for the best compressor for you? Is there any chance to see what you have? It would be best to match it. That way you have the same duty cycle and pressure rating for your switch. You want to run 150 psi or 200?
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 02-25-2009, 02:30 PM   #6
hotrodhomi
hotrodhomi's Avatar
I run a 150PSI PS. Two electric compressors will take FOREVER to fill 10 gallons. You might want to reconsider. If you think you need ten gallons you probably plan on playing with the switches. You are not going to want to wait for the electric compressors to fill up, it sucks. Try a york with and use your electric compressor for backup.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-25-2009, 02:38 PM   #7
smashingchuck
please, no pot stirring. thanks.
III. No pissing matches. Its fine to disagree, but once a thread has run its course, and degenerated into little more than an insult fest, it will be locked. While this will require a judgment call by the Administrators & Moderators. The members of this site can keep our moderating to a minimum by exercising a little discretion and self- control. Excessive profanity will lead to a 24 hour suspension at the Administrations discretion.
IV. Pure trolling, either to upset someone or simply for your personal enjoyment, is strictly prohibited. If you're here to cause trouble, it will be a very short stay. Immediate BAN and you will be reported to your ISP.
78 Build Thread
4Runner Build
Old 02-25-2009, 03:19 PM   #8
Kayotic
Kayotic's Avatar
I assumed Viair comp's. were the way to go.
For what you are thinking about the extra tank and 1/2" lines a york might be the best bet.
10gal in the tanks, another gal. in the bags(4) and another half gal. in the lines 1/2" lines.
Again I haven't used any comp.'s but seen Viairs used a lot.
Thinking: It takes a tad over 2min for an elec. comp to fill 5gal's from empty.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-25-2009, 03:51 PM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The Viair that I do have is a 150psi unit. The truck is over 100 miles away in storage, but I will be getting it out in a few weeks. If I run out of air with the two 5's, that's ok. I plan on tieing the 2 tanks together. I just wanted to gather some more info about compressors before I make the purchase. Thanks!!
