Old 02-19-2009, 03:00 AM   #1
powerbench
powerbench's Avatar
leaf to coil change over
Well i finally got the box pulled off the truck and grabbed a few of the brackets off the old truck....humm no exisiting holes to bolt them two. The holes are in the cross member for the trailing arms , and the only other holes that i see that i can reference off are for the coil spring cup . Is this normal? I also see that i have some stiffening ribs stamped into the frame that are not on any of the coil spring frames i see on here (right beside the spring hangers).I'm also thinking of doing a "c" notch now while i'm torn down..Any body have any pics i can get my points off of? And while i'm at it....i'm thinking of doing the holes through the cross members for my exhaust, should i use a tube ( 3-1/2 ) and weld it in place or fill the pie cut section then cut my holes...or just cut the 3 inch hole and pass the exhaust through that...Thanks
powerbench is offline   Reply With Quote
Old 02-19-2009, 03:42 AM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: leaf to coil change over
Thats all I would think you would need on the frame because your shocks bolt to these little plates that bolt onto your U bolts under your trailing arms. Ohhhhh yeah you might have to fab a place to connect your pan hard bar. I have never heard of anyone converting to coil springs but I have heard coil springs are alot smoother riding. I wouldnt know because I have never driven my truck as it didnt have a power train in it when I bought it. Take some pictures I am curious to see how this turns out
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
