Old 02-19-2009, 04:40 AM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Straight 6 & V8 Engine Wire harness? "Pink Wires"
Hello guys me again I recently pulled my motor out and I didn't mark my wires So I went to put the Motor back in I was left with one or two extra wires My truck was Origanally a inline 6 now it is a V8 I have tried searching the Site Threads for this over and over and came up empty handed I found no Wiring Diagram for a 6cylinder Engine wire Harness What Is The difference in the The Straight 6 and V8 Wire harnesses? My truck is a 72 Chevy.... My Engine Harness consists of 6 wires...Wire#1.is Tan and goes to my Proportioning valve.Wire#2 is Dark Green and goes to my Temp gauge. Wire#3 is Small Pink my guess would be Dizzy. Wire#4 is Big Pink Don't Know where it should go? Wire#5 is a Short Brown/White Wire & I Don't know where it would go.. and My #6Wire is Purple and Im guessing this one goes to the Starter solenoid... My qestion is with my Pink Wires the smaller one has writing on it that reads Do not cut Resistence Wich would make me think this is for the Dizzy Now I am left with the bigger of the Two Pink wires Does anyone know where it should be hooked up to I had it hooked up to the Juction block well I was wrong it was causeing my truck and accessories to stay on these two wires seem to be tied into eachother Hot when Ignition On? For now I have this wire attached to nothing I started my truck and it fired up fine and turnned off fine. Im just wondering where I went wrong & dont want to leave a wire of that gauge left in the loom unused .....As for the Brown/White wire I don't really think I need it for anything...I hope you guys can help Thanks again in advance .......Pablo
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 02-19-2009, 06:56 AM   #2
brak
brak's Avatar
Re: Straight 6 & V8 Engine Wire harness? "Pink Wires"
Here's a wiring diagram i got from another member. it should answer your question.
On a side note, are you still using the original style distributor, or did you swap to HEI?
Original - wire up exactly like diagram
HEI - you will need to remove the resistance wire (there's a good writeup in the tech section).
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-19-2009, 07:01 AM   #3
brak
brak's Avatar
Here's the whole diagram if you want that too
Old 02-19-2009, 09:07 AM   #4
petey-pablo
"THE GREEN GOBLIN"
Thanks brak
No I am not using the original style distributor I have a MSD with A Blaster Coil..
I have looked at this Wire Diagram already over and over and it does not show the wires on my harness I am talking about, Could be It's from a V8 My truck has the origanal Straight 6 NoN/AC Engine harness it came with.. This V8 Diagram Show 7 wire wich none of them are Pink the two that are tied up on mine. My harness has 6 wires as I stated a bove Thanks...
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 02-19-2009, 10:11 AM   #5
68gmsee
Active Member
68gmsee's Avatar
I'll check my 68 GMC. It has the original wiring on it.
When I changed to an HEI dis, all I did was add a 12 guage wire from the firewall connector to the pos side of distributor leaving the original dis wire in place. I left the rest of the wiring intact.
68gmsee is offline   Reply With Quote
Old 02-19-2009, 11:05 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Checked my wiring. It's different than yours to some extent. I have 4 wires coming off the top. I don't have the wire for the oil sw and no wire off to the backup lite as the diagram shows.
The bottom half pretty much follows the diagram.
Old 02-19-2009, 06:07 PM   #7
petey-pablo
"THE GREEN GOBLIN"
My wires still look nothing like the diagram pictured above I have 6 wires Heres some pictures Hope someone can help..... I have 6wires 5 pins The two Pink wires are tied in to the sam pin... The Smaller Pink wire is the one labled Resistance Do Not Cut So my guess this one would be for the Dizzy, But the biger one I have no Idea where it goes..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 02-19-2009, 06:30 PM   #8
john
member #16
john's Avatar
Heres another diagram with a 12ga pink coming from the ign sw. which sounds about right.
john is offline   Reply With Quote
Old 02-19-2009, 07:31 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Here's a possibility.
Since yours is a 72 maybe the thicker pink wire was for the possibility of an HEI distributor. Never know what these engineers projected on these vehicles. The recommended guage for the HEI is 12 guage.
The small pink wire (resistive) is for your points distributor. That wire looks like it's probably 14 guage.
Old 02-19-2009, 11:42 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
I don't think those wires are pink I think they are faded red. Here is a picture of a switch harness, the top wire is faded red and the bottom wire is pink.
LockDoc
Leon
Old 02-20-2009, 12:39 AM   #11
joemacho
joemacho's Avatar
the brown and white wire is your horn wire and the big red wire goes to your voltage regulator and your alternator.
joemacho is offline   Reply With Quote
Old 02-20-2009, 01:09 AM   #12
Fubar
Fubar's Avatar
I've got a pink wire in mine too, but mine is tied to a white wire also. I was thinking it is the wire going to the starter/coil that is labeled 20w/ or-ppl ?
Fubar is offline   Reply With Quote
Old 02-20-2009, 01:42 AM   #13
Fubar
Fubar's Avatar
sorry I just realized how bad my pics are.It's hard to tell but the wire on the far right is a purple wire, the pink and white one's are to the left of the purple. Also my v.i.n say's my truck came with a v-8 but I pulled a six out of it.
Old 02-20-2009, 05:58 AM   #14
petey-pablo
"THE GREEN GOBLIN"
I am talking about the Engine wire harness Not the Horn and Light harness thanks, I will try to take a Better Picture Later today These were taken using a Camera Phone. I will use a real camera today thanks. I am Just wonder ing where these wires go..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 02-20-2009, 06:01 AM   #15
petey-pablo
"THE GREEN GOBLIN"
Did they make diferent wire harnesses for Straight 6 Motors besides Ac and Non /Ac trucks? So far from what I have seen no one has a simular harness.. These two wires are Ignition Hot Only Not Constant Hot...
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 02-20-2009, 10:10 AM   #16
68gmsee
Active Member
68gmsee's Avatar
Re: different wiring harness: I have read where they did use different color wires on these trucks. Usually the exception, but it did happen.
Re: two pink wires. You say ignition hot only? Doesn't make sense. If they're tied together and the resistive wire is for the points distributor, then both should have 12 vdc. Maybe someone messed with the wiring in the past??
In my truck, if some future owner were to look at my harness, they may see a blue 12 guage wire for the HEI on the same connector with the resistive wire -It was the only 12 guage wire I had.
Old 02-23-2009, 01:44 AM   #17
joemacho
joemacho's Avatar
sorry about that petey but i was to refering to the engine harness also cause there are only two wires that are for the engine 1 for the starter, 2 for the coil or the wire for the dizzy distributor the other three wires are for the temp, brake, and the horn...
Last edited by joemacho; 02-23-2009 at 01:47 AM. Reason: sorry mispelled name missed a word
Old 02-23-2009, 01:56 AM   #18
petey-pablo
"THE GREEN GOBLIN"
It's ok I havn't figuured it out yet Ben out sick since thursday. I am ganna get back to it this week Yup your right the Purple wire does go to the Starter and the other smaller pink wire Is supose to go to the Dizzy But the biger pink I have no Idea where it goes They are both tied in together and Both Ignitoin Hot.. I was thinking of just Removing the smaller of the two pink wires and useing the bigger one to feed my Painless Fuse block under the hood and run a separet wire to the Dizzy..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 09-28-2013, 12:52 PM   #19
Chulisohombre
Chulisohombre's Avatar
If I remember right the thicker one goes to the alternator. The thin pink was the coil wire. You can use the thick one on the coil since its keyed power. If you use it for a junction block power it still goes through the ignition and could heat up the internals on it. Mine kinda melted and I had to replace it. You could use it as a circuit and turn on a breaker with a better battery connection like some have done then have full power to whatever you connect it to. On my 72 I power the coil off the acc spot on the fuse block.
Chulisohombre is offline   Reply With Quote
