Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-19-2009, 10:10 AM   #1
6600DURAMAX
6600DURAMAX's Avatar
Need some an fittings
Looking to buy some used or left over AN fittings from a previous build or just some someone is trying to get rid of.
I need:
For Trans. Fluid
6AN – (6) straight
6AN – (2) 90 degree
For Fuel Line
8AN – (6) straight
8AN – (20 90 degree
8AN – (1) 3/8’’ barb end straight
Also need
20ft of 6AN stainless hose
15ft of 8AN stainless hose
let me know if anyone has any of the above or at least something I can make work
Thanks guys
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-19-2009, 11:50 AM   #2
Wild83C10
Wild83C10's Avatar
Re: Need some an fittings
I have the following:
3 6AN 90s
1 6AN 45
1 4' section of 6AN hose
3 1' section of 6AN hose
I just sold a bunch of 6AN and 8AN hose at the swpameet last year.
I don't recommend using SS rubber lines for fuel. The fuel will eventually eat away at the hose and the vapors will seep through the hose and stink up the garage. I switched to teflon lined hose and my garage doesn't stink of fuel anymore.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-19-2009, 12:21 PM   #3
6600DURAMAX
So is the Teflon hose have a stainless covering?? Or is it like the blue push lock type of hose?
Old 02-19-2009, 01:13 PM   #4
cdowns
cdowns's Avatar
a good place for finding used fittings and hoses is racingjunk.com
Old 02-19-2009, 03:45 PM   #5
Wild83C10
Wild83C10's Avatar
The teflon hose is covered in SS braid just like the rubber hose. The overall diameter of the teflon hose is slightly smaller because of the teflon vs the rubber hose. But the teflon has a larger bend radius so you can't make as tight a bend. It is also more expensive.
It was worth it to me though. My wife was ready to kick the truck out of the garage since the smell from the fuel was so strong.
turbo=
Old 02-20-2009, 12:34 AM   #6
scatesracing
Machinist
scatesracing's Avatar
http://www.musclemotorsports.com/aer...ne---ftgs.html
check this place out.......... I found it five or six years ago
scatesracing is offline   Reply With Quote
Old 02-20-2009, 04:23 PM   #7
Wild83C10
Wild83C10's Avatar
Wow those are some good prices. Nice find scatesracing!
turbo=
Old 02-20-2009, 07:55 PM   #8
scatesracing
Machinist
glad I could help... I found that back in the dial up days....... 56k LOL. They also have "truck type traling arms" to I was thinking about ordering one to see if they will fit the 60s and 70s trucks???? only $50 Travis
