Old 02-19-2009, 12:50 PM   #1
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
67-68 core support bushing
can someone tell me the thickness, if they are different than 69-72?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 02-19-2009, 01:47 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 67-68 core support bushing
the thickness is the same 67 - 72
Old 02-19-2009, 02:02 PM   #3
vasquezmrysvll
"the other guy"
iv read alot of threads which state that the thickness of the bushings are different? can some one please explain this?
Old 02-19-2009, 02:09 PM   #4
Musclerodz
I think there is a difference from 2wd to 4wd
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 02-19-2009, 02:14 PM   #5
otsenre
otsenre's Avatar
I have heard otherwise, In fact I bought some for my 4x4, vendor told me they were all the same, sure hope so as I havnt installed yet
otsenre is offline   Reply With Quote
Old 02-19-2009, 02:20 PM   #6
vasquezmrysvll
"the other guy"
read #6 or 7 and down
http://67-72chevytrucks.com/vboard/s...pport+bushings
Old 02-19-2009, 04:59 PM   #7
Longhorn Man
When I was doing the 68 front clip onto my 72 burb, i had remembered talk of core support bushings. I cracked open my parts illistration catalog (LMCrap) and they listed the same p/n for all 6 years.
I used the stock 3/4 ton original 72 pieces, and it all went together fine.
Is there in fact 2 p/n for core support bushings?
Old 02-19-2009, 05:21 PM   #8
breeh
Recovering 67-72 Addict
breeh's Avatar
The core support bushings on a 67/68 are more like rubber washers. You can use the 69-72 style but it is necessary to shim the front cab supports a bit to get it all to line up properly. I have not seen that the original type for a 67/68 are even available.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 02-19-2009, 06:46 PM   #9
vasquezmrysvll
"the other guy"
i think im going to cut my urathane ones into 1/4" slices with the old band saw,and use them accordingly. my gaps are WAY off with a whole bushing in there.
Old 02-19-2009, 09:44 PM   #10
HOTFUN
HOTFUN's Avatar
Breeh is correct and Ernest (Otsenre) and I took apart an original 67 C20 clip off a frame of his a couple weeks back. They are totally different from the 69-72's I have took apart as they are just a 1/4 inch thick rubber like a piece of tire size bushing sandwiched between the frame and the support. If I remember right on Ernest's support it had the rubber piece against the support, then a large maybe 1.25" steel washer on top of the frame. Since then I looked at a couple more of my 67's and it is pretty easy to tell it is tight between the frame and the radiator support. My 71-72's all are 1/2 to 3/4" between the frame and the support. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 02-19-2009, 10:29 PM   #11
otsenre
otsenre's Avatar
So like green machine says, if its a 72 frame, I can still use the 69-72 supports with the 68 front clip I am adding. Thats a relief
Old 02-19-2009, 10:32 PM   #12
Tim Christian
Tim Christian's Avatar
They are totally different! 67-68 takes one style and 69-72 takes a diffrent style! That is why some of you guys aftermarket sheetmetal will not fit! LOL!! Just kidding but they are diffrent. I do have both with hardware in stock. Let me know if I can help you. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 02-19-2009, 10:43 PM   #13
otsenre
otsenre's Avatar
Just the frame, right? I can use the 69-72 supports on my 72 frame with a 68 clip, right?
Old 02-19-2009, 10:45 PM   #14
Tim Christian
No you must use a 67-68 Rad. mount kit with a 67-68 front end or it will set up to high if you use the 69-72 rad mount kit.
Old 02-20-2009, 12:11 AM   #15
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Okay, so what's the price for the complete 1968 cab/core support mounting kit? I need the bushings and hardware for the core support and front and rear cab mount. I wasn't able to find it on your web site. Plus shipping to 92126 area.
Thanks.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
