02-19-2009, 06:18 PM | #1 |
help ID this block
3970010 i thought it was a 350 but it is not
02-19-2009, 06:35 PM | #2 |
Re: help ID this block
i have a 1969-1980 350 2 or four bolt main unsure.
its one if those "high nickle content" block ...i dont know if that means anything to you, they are apparently a tougher block...
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
02-19-2009, 06:57 PM | #3 |
so how do u tell if it is a 350 or a 307 why i ask is i went to get a starter for it and the one on the truck was for a 307 but when i rebuilt the eng i used 350 parts. so will a 307 starter work on a 350
02-19-2009, 06:59 PM | #4 |
Old Shovel Rider
Mine's a 0010 too. It was originallly a 327. Some of the very first (68 - 69) large journal 4 bolts had 327 rotating assemblies. The deck height's the same (9.25 I think??) I had it bored .030 over and used a 350 crank and pistons with the 5.7 rods to make a 355. A 383 build is doable too !!
The starters for automatics and manuals bolt up differently. Otherwise, You should find they interchange. The starter I'm running came off my original 6 cyl. The bell housing and starter are the same on both. Last edited by DB Smith; 02-19-2009 at 07:19 PM. |
02-19-2009, 10:06 PM | #5 |
That's just the casting number-fits hundreds of applications.
The good numbers are on the block surface just ahead of the right side head.If it hasn't been decked! It tells what you need to know. Mike. |
02-19-2009, 10:26 PM | #6 |
It can be a 302 or 327 or 350. All have the same bore just different stroked cranks. You can use a 350 crank and the starter depends more on the flywheel size then the engine size. Hope this helps.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
02-19-2009, 10:29 PM | #7 |
cool monte0185 that is what i need to hear lol
02-19-2009, 10:32 PM | #8 |
02-19-2009, 10:35 PM | #9 |
I have a radical idea!
Most blocks have 3 starters holes on the bottom and will accept the diagonal and straight across mount starters, some blocks only have the 2 holes for the diagonal pattern. I discovered this while trying to bolt a mini starter on a 3970010 block years ago and it didn't have the hole drilled for the straight across pattern that my mini starter needed. I had to drill and tap the block to bolt my starter on. This may be your issue.
As monte0185 said, a 3970010 block is definitely not a 307. It is a 4" bore block and they came as 302, 327, and 350 from the factory.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-19-2009, 10:38 PM | #10 |
02-19-2009, 10:46 PM | #11 |
thanks guys i see the three holes for the starter now
02-19-2009, 11:00 PM | #12 |
Learning As I Go
ive got the same one and its a 350 four bolt main 3970010
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
02-19-2009, 11:44 PM | #13 |
The last 3 random sb I got were that same casting #.
