Old 12-13-2002, 01:41 AM   #1
mikep
Used to have a truck
mikep's Avatar
Birthday roller rockers installed
I started pulling the valve covers at 8:02 PM and was finished installing the new rockers at 9:12 PM. Competition cams chrome moly 1.6:1 pro magnum roller rockers. Gave me a good bit more lift and a lot less valvetrain friction.
Happy birthday to me. My birthday roller rockers present to myself are now installed ! I Took it out for a drive but its hard to get a feel for the road when its wet. This is the seattle area in the winter you know. The tires broke loose at 50 mph ....duh ...
No truck :-(
mikep is offline   Reply With Quote
Old 12-13-2002, 08:58 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Did you have to get new springs?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-13-2002, 09:16 AM   #3
mikep
mikep's Avatar
I didnt use new springs.My heads are world product SR torquers and they came with new z 28 style springs, guide plates and screw in studs. The sprins in them are good for .550 lift.
No truck :-(
Old 12-13-2002, 09:18 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Thanks. I've heard those heads are nice for the money.
Jim
Old 12-13-2002, 09:44 AM   #5
bigjimzlll
bigjimzlll's Avatar
Did you inlarge the push rod holes? I read an article/post that said wrld heads had to have this done or the rods would bind. If you want, I can try to find the article/post.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 12-13-2002, 10:13 AM   #6
crazy longhorn
Fabricate till you "puke"
Thats a nice lookin set of rockers......Oh, happy B day man! How much did the pushrod lenght change , going to full rollers ?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-13-2002, 11:51 AM   #7
mikep
mikep's Avatar
Its the newer World Product heads that need to have the pushrod slot enlarged. Mine are an older '94 produced set that had been in storage until I installed them this year. The newer ones have the bosses cast in for centerbolt valve covers in addition to the perimeter bolt holes and have the pushrod slots machined in. The newer ones also do not come with guide plates although they do have screw in studs. I didnt have any interference problems and used the same standard length hardened pushrods I had been using previously . Preliminary reports are that I have a good bit more seat of the pants power. 10-15 HP maybe.
No truck :-(
Old 12-13-2002, 03:42 PM   #8
Low69CST
aren't those rockers supposed to have a girdle across the nuts to keep them from backing off??
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 12-13-2002, 04:37 PM   #9
mikep
mikep's Avatar
Girdles just stabilize rocker arms in hi rpm / hi tension valve spring applications.
The nuts on these have an allen set screw in the middle that jams against the tip of the rocker stud to keep the nut from turning.
No truck :-(
Old 12-13-2002, 08:53 PM   #10
67shortie
Green club
67shortie's Avatar
Happy birthday Mike
Those are one of the best rockers money can buy, for off the shelf stuff. I ended up buying the Crane aluminum, the large cam I run liked the full roller. Congrats on the new toys
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 12-14-2002, 01:13 AM   #11
Johns70
Johns70's Avatar
mike you gonna try them this spring at bremerton at on of the test and tunes?
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 12-14-2002, 01:24 AM   #12
mikep
mikep's Avatar
If I can get my neutral safety switch working.
Pain in the ass tech inspections! Bremerton raceway is about 5 miles from my house.
No truck :-(
