![]() Join Date: Dec 2008
WTB/need front factory sway bar frame mounts
My truck has a factory sway bar but it has come to my attention the PO has taken a torch to remove it and cut up the mounting brackets rather nicely as well as enlarged the holes in the fame.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
Re: WTB/need front factory sway bar frame mounts
PM sent
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
If the truck is lowered you can usually ditch the frame mounts all together and bolt the swaybar bracket right to the frame.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 02-20-2009 at 12:48 AM. |
It only has 2 1/2" spindles and a 1" spring.
Under Construction
ECE sells lowered frame mounts as well. as stated you can also bolt directly to frame.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
