Old 02-20-2009, 12:51 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Redrilling front rotors
Have any of you done this at your shop ???
If so what are your opinions on the best way to do it
I want to ReDrill my front rotors from 5x5 to 5x4.5
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-20-2009, 01:05 AM   #2
Twisted Minis
Twisted Minis's Avatar
Re: Redrilling front rotors
I outsource it to a machine shop.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-20-2009, 11:00 PM   #3
Scottshotrods
we have a fixture we made that bolts on our mill that
holds them in place.You can
buy the rotors already drilled with the bolt pattern
you want.You do not have to be bothered with it.
justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 02-21-2009, 01:40 AM   #4
Shane
Shane's Avatar
Originally Posted by Scottshotrods View Post
You can
you want.
Do you have a a link for 5 x 4.5" calipers for truck spindles?
Shane is offline   Reply With Quote
Old 02-21-2009, 09:08 AM   #5
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
I sent my rear axles off to http://www.moserengineering.com/ to get them re-drilled. VERY QUICK turn around. They also do hubs.
p8ntballer1911 is offline   Reply With Quote
Old 02-21-2009, 02:05 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks guys
My rear is already 5x4.5" as it is a ford 9"
Sinister
Killer
Old 02-23-2009, 12:40 PM   #7
HotRodYJ
HotRodYJ's Avatar
I redrilled my rear axles and drums last week myself at home. I layed out a templete in CADD at work and then transfered it to a metal templte once I got home. The templete bolts to the existing lug pattern so I can centerpunch the 5 new hole locations. Then I made a simple jig on my drill press to hold the axle shafts nice and flat and drilled them. Easy as pie. A front rotor shouldn't be any harder than that assuming there is no webbing on the back side to get in the way of an offset new pattern. The drums and rotors both lay flat on a drill press so all you should need is a templete to get the hole locations correct.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 02-23-2009, 01:43 PM   #8
SCOTI
SCOTI's Avatar
There is 'webbing' that interferes. I'm not sure how difficult it would be to overcome for the DIY'er @ home.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-24-2009, 02:07 PM   #9
HotRodYJ
HotRodYJ's Avatar
Screw in studs could be an easy answer. What do the machine shops do? Do they machine down the "webbing" and weaken the rotor?
