![]() Join Date: Dec 2001
283 or 307
My brother is giving me a 283 out of a '57 chevy he is restoring. (It is actually out of a '65 chevy). Would the 283 be better to rebuild than the 307 or just save my money for a 350?
Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Step Brother
Re: 283 or 307
It really depends on what you are wanting out of a engine....H.P. or Reliability or fuel mileage....All of the engines you have listed are good engines....
Re: 283 or 307
Save your money and get a small block 400 ,,,,I sold my 307 out of my truck and did this and I could not be happier....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: 283 or 307
![]() Join Date: Jan 2008
Re: 283 or 307
Why would you donate the crank and rods to have less cubic inches and less horsepower? I'm with Big Al, after having all the little motors, I'll never have anything but a 406 small block or larger. Try it, c'mon, you might like it!
Re: 283 or 307
283 is better than the 307 also the 302,DZ if you can find one than also the 327 305 350 400 are all good engines too
Old Skool Club
![]() Join Date: Jun 2001
Re: 283 or 307
A 283 block combined with a small-journal 327 crank yields 301 cubic inches. Okay, maybe 301.6, hence the 302 was born in late '67.
The saying, "there's no substitute for cubic inches" is why we have 572 cubic inch big blocks. But, a sneaky small block, back in the day, woulda been way cool. Imagine having a 406 small block back in '64, in a Nova SS. If you were around then, you remember that Chevy offered them with a 283 and we were happy. At the same time, Ford was offering the 260 in a Falcon and Plymouth was selling Valiants with 273's. So, a small block 406 woulda made you some money in a clandestine drag on the streets. As it was, we just put the biggest engine we could fit into whatever we could and then had to monitor and adjust our driving to be able to live with it. A friend had a '63 Dart that had a 383 out of a Chrysler in it. Did it fit? Barely. Did it run? Oh yeah. Did that little 8-inch rear end hold up very well? Yeah, for one week, then it was time to swap it for another one. I just sold a '56 265 (late style with oil filter mounting) for $25 to a friend, after another friend cleaned out his garage. Minus the heads, intake and oil pan, the buyer is happy as a pig in mud. Very little ring groove, not too much slack in the timing chain....it'll take a rebuild and be a good engine, again. As for the decision to build one or the other.....you gotta shop around and be sure you don't through good money after bad. A 350 will build for the same dollars and be more engine in the long run. There will be a day when the 350's, at least the good ones, will be scarce as 283's and 327's. I know that the vortec 350's are more common now than the 350's that came in the '69-72's, but that's life.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: 283 or 307
Less horsepower? What formula are you using? The 400 block is weak. Plus parts are expensive.
I have a radical idea!
Re: 283 or 307
All things being equal, 406 cu inches will make more HP than 383 cubic inches every time. That being said, some 400 blocks are suspect when bored (and some when not bored) due to thin cylinder walls. I love 383's have built and ran them for years, but if I were building a SBC for max power with a good thick aftermarket block, it would be a 4.125"+ bore engine.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-20-2009 at 11:21 PM. |
Re: 283 or 307
I forgot about the '65 Nova SS I had with 283 Powerpack and PowerGlide, ran like a scalded dog. Man, I wish i still had that one.
#11 | |
![]() Join Date: Jan 2007
Re: 283 or 307
sorry, but a 302 chevy was a 327 or 350 4 inch bore block with a 283's 3 inch stroke crank in etheir small or large journal small was 67-mid 68 large was mid 68 - 69, also i'm not a a 100% without doing the math but i think the combo your talking about is how the they got the 307.
ASE MASTER TECH
Jason
Re: 283 or 307
Off subject but when I purchased my truck it had a strong running 305
headers, aluminum intake, aftermarket cam, holley carb etc. I blew it up and replaced with the GM Goodwrench Universal Crate 350 swapped cam before install with Comp XE262h and there is no comparison. Save up for the 350 in my opinion and if you won't to spend more money go for the 383 or 400. |
#13 |
Re: 283 or 307
I`ve been perfectly happy with totally stock 283s and 307s.It all depends on what you want.They are all good motors.The Z/28 motors were the large journal 327 blocks with 283 stroke.That`s an engine for racing.A light vehicle and high rpm range are what they`re good for.There is a replacement for displacement.That`s why the bigger motor doesn`t always win.We need to know what a guy wants from his motor before we should recommend anything other than what he`s asking.As far as the question goes,I`d say build either.Their`s not much difference.They are both great motors.You can set up one of these motors to get best mileage of any small block.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-21-2009 at 11:51 AM. |
#14 | |
Re: 283 or 307
![]() mid 9's on a just a little juice and we used 23 degree heads. Put a set of 12 or 15 degree real race heads and they'll make stupid numbers! You are right that the 283 block with 327 stroke crank is the 307. You could actually build a 307 with a small journal 327 crank. I say it that way because 307's had large journal cranks, and you can't actually use a 307 crank in a 283 block. The hot ticket in super late model dirt cars is building a 400 (aftermarket block, of course) with forged Callies or similar 327 stroke crank. A lot NASCAR builders use a similiar bore/stroke combo as well, but they vary slighty to thir liking. A lot of classes have a 362 cu in rule limit (NASCAR has a 358 cu in limit), and a .060 over 400 SBC 4.185" bore and the 327's 3.25" stroke comes in at 358. Those puppies will rev to the moon! We built one of those 3 years ago, and was the most wicked revving SBC I'd ever built. We built for it for a tight local 1/4 mile oval track, and you have to run alot of gear, but they are awesome. Draime and Clements among others build a lot of these.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#15 |
Re: 283 or 307
I guess what I want is the best of both world's, more HP and decent milage.
#16 | |||
Re: 283 or 307
See below that is a 540 hp built naturally aspirated motor that runs as great as it looks,,,,trust me ![]()
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 02-21-2009 at 11:53 AM. |
#17 |
Re: 283 or 307
The 283 and 307 are what you want for best mileage.You can buld them to run like a 350 and not give up fuel economy.But,if you want power as much or more than economy start off with the 350.You can build a spunky 283 or 307 with the right cam.head,ignition,exhaust,and carb combination.Up the spark,small spread-bore 4bbl,better flow,more low-end torque will do it.
#18 |
Rods
![]() Join Date: Nov 2002
Re: 283 or 307
USE THE 57 283 BLOCK. THE CASTINGS ARE THICKER.. i HAVE SEEL 1000 HP FROM A TURBO 57 CHEVY.GOOGLE IT. THERE IS A FULL WRITE UP ON IT. YOU CAN BORE THAT BLOCK TO 60 WITH NO WORRIES.
#19 |
Re: 283 or 307
See below that is a 540 hp built naturally aspirated motor that runs as great as it looks,,,,trust me how is that for weak?
Where do you people get the horsepower #'s? Has this motor been on a dyno, or are you just guessing? Just because a part says it gives you an extra 10 hp. doesn't mean that's what you get. When I said the 400 block is weak I was referring to the tendency for them to crack. |
#20 |
Old Skool Club
Re: 283 or 307
[QUOTE sorry, but a 302 chevy was a 327 or 350 4 inch bore block with a 283's 3 inch stroke crank in etheir small or large journal small was 67-mid 68 large was mid 68 - 69, also i'm not a a 100% without doing the math but i think the combo your talking about is how the they got the 307.[/QUOTE]
Thanks. When you posted your comment, my CPU was reset. I don't recall any 4-bolt main 283's and wasn't that what the 302's had? You're absolutely correct in your comment. Again, thanks for clarifying it for me.
#21 |
Re: 283 or 307
If you have the 307 build that, it will be a little cheaper to build than the 283 and give you more torque than the 283 will. Find a set of 305, 416 casting heads and you will have a nice running little engine, just dont expect to pull 10,000 pounds over the mountains at speed.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) Last edited by bhoeger70; 02-21-2009 at 04:31 PM. |
#22 | |
Re: 283 or 307
Dynoed in an engine room, that was to the flywheel. It has not been dynoed since installed in the truck.
#23 |
Re: 283 or 307
get a 2 bolt 400 block and have your machine shop splay the caps. guys have run over 700+hp with those and rarely ever break. I have a buddy that ran his straight 2 bolt with about 500hp for like 5 years before the block cracked... putting on 5000+ miles a year
#24 |
What?
Re: 283 or 307
I didn't read anything about what you are going to use this new motor for here in this string, so recomending something to you at this point is all about everyone's favorite mill.
If you just plan to put one of those motors in a DD pick up, I'd say go with the 307 just because it's "newer" and parts will be more plentifull. (though SBC parts are very interchangable so it's kind of mute) What kind of transmission? What gear ratio is in the axle? Daily driver? Tow vehicle? Sleeper hot rod? Family camper? budget? Personally out of the stock (not stroked) older small block motors, my favorite is the large journal 327 power plants. Thats what I have in my K20 burb with a 4 speed and 4:56 gears, this engine has pulled travel trailers over many a mountain grade with 100+ degree temp. days. It has the grunt, and the RPM range to handle just about anything. Sure I wasn't doing 70mph while pullin those grades, but if I wanted to I would just put a 396 or a 427 in it. But then that wasn't practical for my situation. When I was building my 327, I stuck a 350 in the burb from one of my other projects (72 Camaro). This 350 was fresh and not stock, and was nice a motor for a Camaro. But, in the burbs drive line it was the most boring and piggish motor ever. I couldn't wait to get my 327 back in! All that is just my opinion driven only by my personal experience. You can argue for days as to what to do with a Chevy small block, but what it really boils down to is how much money you want to invest. Plus making sure your investment is done wisely for what you need. Good luck!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#25 | |
FarmBoy.
Re: 283 or 307
I won't comment on whether you should save for another motor, simply because I am a firm beleiver in using what I have on hand.
Regardless, I run a tired 307, with 2 bbl and headers, 3.07 gears, etc (it's all in my sig), and I'm very content with the motor. It's approaching the 100,000 mark, and has never been apart. It's starting to burn oil, and god know what else. But, I still squeeze out high-teen's for mpg's, and have enough snot to get up to highway speeds in a fair clip, all things considered. Am I bias? Of course. If you're looking for an all out race motor, 283/307 isn't your ticket without alot of money invested. But with a nice rebuild, bump the compression and cam, headers and a nice flowing 4-bbl, you'll have a good performing engine, gets respectable mpg's (pending gear ratio and driving style), and unless you're out head hunting at stop lights, should give you enough power to satisfy your needs as a daily driver. Just my opinion. -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
