Old 02-20-2009, 08:25 PM   #1
JesseSimon
Asks alot of questions
JesseSimon's Avatar
Front end conversion question
Does anyone know if you can take the disc brakes and front end parts from a mid 80's van and drop them in a '69 C10?
JesseSimon is offline   Reply With Quote
Old 02-20-2009, 08:29 PM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Front end conversion question
You could use the rotors and calipers i know but as far as the rest just get you some spindles.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-20-2009, 08:31 PM   #3
JesseSimon
JesseSimon's Avatar
I'm beyond amateur so bare with me... Are you saying I just need to change out the spindles in order to use the disc brakes from the van?
Old 02-20-2009, 08:55 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
The ball joints are different...you couldn't just change out the spindles. Also, the outer tie rod ends currently on your truck wouldn't work with the van spindles even if you swapped the ball joints. They make conversion tie rod ends, but I'm not sure if they have them for that van or not. Most folks swap out entire crossmembers. I swapped the control arms, tie rods, centerlink, etc., etc. from an 89 'burb. I know you can do this with 73-87 trucks and 73-91 'burbs but I'm not sure if the vans are the same as the trucks.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
