Old 02-20-2009, 10:58 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
Porterbuilt- Weld-in Notch- Free Shippping- Till March 31
Hey guys, I finally got around to getting my weld-in notches all finalized. It's a "mostly welded" weld-in notch, and I have two versions: 63-72; and 73-87.
As pictured they will lay frame with up to a 32" tall tire. If you're running a smaller diameter tire, or not quite wanting it so deep, you can trim it down to fit, or I can build them shorter.
Below are some pics of both versions. They come as pictured, including the ground and finished edges.
The "Mostly Welded" notch kit runs $299, and the "Unwelded" notch kit (pieces only) runs $175. I will be throwing in free shipping anywhere inside the continental U.S. until the end of March.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-20-2009, 11:02 PM   #2
Scottshotrods
Re: Porterbuilt Weld-in Notch
looks nice
justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 02-21-2009, 12:54 AM   #3
Rokcrln
Rokcrln's Avatar
What no install pic's! Slacker
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 02-21-2009, 01:06 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
Kevin
LFD Inc.
I don't work quite as quick as you do! I guess it's because I am human, and have to get more than 3 hrs. of sleep a week!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-21-2009, 08:18 AM   #5
lofly'a
lofly'a's Avatar
NICE!! those things are a work of art.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 02-21-2009, 12:33 PM   #6
lowdownstar
big guy
lowdownstar's Avatar
Hey Nathan your not going to give a set away are you You know where you put guys names in a hat and pull one .... just asking, I feel lucky!!!
looking great as always Nathan!
Sorry coudn't help myself!
lowdownstar is offline   Reply With Quote
Old 02-21-2009, 12:57 PM   #7
Rigo's 70 C10
Nate,
Do these come with instructions on where to weld them in? I have never done this and i am going to do it. I was going to purchase the bolt on system, but if these come with instructions on where to place them to weld them, i know an awesome welder that could get it done for me. Options are always great and if i can save a few bucks in the process, even better.
Rigo's 70 C10 is offline   Reply With Quote
Old 02-21-2009, 01:07 PM   #8
abadsvt
abadsvt's Avatar
Originally Posted by Rigo's 70 C10 View Post
Nate,
It is much easier than you think. Plus there are tons of threads on this forum that give you tons of tips and advice. All you really need to do is jack up your rear end to see where your center line is then put the notchs on the frame and weld. After they are welded then cut the part of the frame that needs to be removed. Then weld that bottom piece that completes the notchs and wala. Your done. That simple if you have basic welding skills. Probably take you a half of a saturday. Plus Nathan makes some really nice, high quality products so if you are looking for some notches i would definatly consider his product. Good luck
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 02-21-2009, 01:41 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
Nate,
These don't come with installation instructions in terms of measurements for placement and depth. I am making them taller than most will need/want, but this allows the end user to trim the height, and place the notch in their desired fore/aft location.
When locating the center-line of the axle (and thus centerline of the notch) I have found that the original bumpstop's centerline is about as close to the center of the wheel arch as you need to get. I use that as a centerline reference. With that said, here's the tricky part: depending on whatever link system you are using to locate the rear-end, the length of your link bars will follow an arc and thus locate the center-line of the axle in different locations as it goes through its travel. I like to set the axle to where its centerline is centered in the wheel well opening when deflated (if running an adjustable suspension). That way it looks "right" when everybody is taking pictures of it at the show!
It takes some careful measurements, but isn't overly complicated. Just take your time, measure several times before cutting/welding... and several more times before you fully weld them up. I am happy to answer any questions that may arise. I know that a lot of the time it's easier to "talk" someone through a process, rather than "type" the way through it.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-21-2009, 01:43 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-21-2009, 02:33 PM   #11
LowRodder
LowRodder's Avatar
I want one! Sending PM
LowRodder is offline   Reply With Quote
Old 02-21-2009, 09:07 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Another great product brought to you by Nate!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-23-2009, 10:51 AM   #13
SCOTI
SCOTI's Avatar
Re: Porterbuilt- Weld-in Notch- Free Shippping till March 31st
Nate..... How 'tall' is the actual boxed section of frame? By that I mean just the frame rail & not 'how tall is the notch'. If the question is confusing, call me.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-25-2009, 12:20 AM   #14
PBFAB.COM
PBFAB.COM's Avatar
The notch thickness is approx. 4".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-25-2009, 12:21 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
I went ahead and editied my first post:
I also sell the kit in unwelded form. It runs $175. The same free shipping applies through March.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 03-03-2009, 12:50 AM   #16
duceducenine
duceducenine's Avatar
how wide is the top of the notch outside to outside?
i want one for my 72 blazer and still use the seat!
whats retail price gonna be after march?
i want to know how many i should buy???
duceducenine is offline   Reply With Quote
Old 03-03-2009, 11:25 AM   #17
PBFAB.COM
PBFAB.COM's Avatar
It's approx. 8.5" long on the top piece.
After March 31st I will be charging shipping... so $299 plus shipping!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
