Old 02-21-2009, 03:01 AM   #1
worley91
Big Boys With Big Toys
Transfer case
What transfer case can I use with the NV3500 when I do my solid axle swap with the f*%^ Dana 60 that is stronger than the stock 88 Chevy transfer case. I plan on playing in the mud quite a bit and using and abusing (not permanently) this truck when its done.
worley91 is offline   Reply With Quote
Old 02-21-2009, 08:32 AM   #2
Re: Transfer case
I`d say the NP241 is ever bit as strong as the NV3500.You can use a NP208 or a late NP205 with the same bolt pattern.I`ve seen two NV4500s be outlasted by their NP241 transfer cases in 1t work trucks.
