Old 12-13-2002, 08:34 AM   #1
Leftlane
Torsion to spring swap?
Hello all.
Thought I'd try and pick your brains before scrapin' my knuckles.
I've got a '62 Chevy 1/2t 2wd stepside shortbed with the torsion bar front end. I've seen where a lot of those with either the older Advanced design or Task force trucks have bolted in complete front crossmembers from a mid '70's to '80's truck. I've also seen where many of you have swapped A-arms and spindles from newer trucks.
Obviously I'd like to get the benefit of power disc brakes and coil springs, (although the bars do ride OK).
On the '62, do I have the option of swapping arms, spindles, rod ends, etc. from a '73-'87?
I know I can get lowered spindles and disc kits from vendors, but was kinda hoping for a junkyard solution as this ones my beater.
Thanks!
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 12-14-2002, 01:18 PM   #2
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Wow, you mean I can put a 71-72 crossmember in my 56? I've never heard that before. Can you point me in the direction of that info? A thread or something would be great.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 12-15-2002, 02:07 AM   #3
Leftlane
Try this.
http://www.antiquechevytrucks.com/Co...ont_suspen.htm
I don't know yet if this is applicalbe to the Task force trucks, but I've seen a few of the AD trucks done this way, track is a little wider though. I've also got a '57 and was going to look at this a little harder, but was leaning towards the Heidt's IFS.
Hope that helps??
