factory engine vacuum routing
could someone tell me where i might find the proper vacuum routing for a 72 402/400 air ,cruise,and a 72 350/350 air
Old member
Re: factory engine vacuum routing
This is the cruise stuff.
![]() Here is what 78 Chevy posted Here is another from JimKshortstep4x4
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-21-2009 at 10:25 AM. |
factory assembly manual shows the proper location and routing as well as attachment points of the vaccume lines as they came from the factory
assembly manuals available from most vendors as well as on ebay
I need this info too for a 72 350 manual trans with A/C
Went through the whole assembly manual and it wasn't there.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
#5 | |
look again its in there
For a 350? I only saw 6 cyl info
