Old 02-21-2009, 12:05 PM   #1
69gumby
69gumby's Avatar
350 Engine Pics / Air Cleaner Options
I am changing the carburetor on my truck to an Edelbrock 1406 and while I was making the swap I found an Aluminum Edelbrock manifold on my truck. It was just hidden under a fine layer of patina, ok old grime. I have just about got things finished except for the Air Cleaner. My old one was a 10"X2" and as I read the Edelbrock Owners Manual they say I need a 14"X3", I always thought my truck ran a bit fat.
I would like to see what other folks are running.
How did you hook up the breather tube or is putting a breather in the valve cover better?
69 sweet long fleet, David
69gumby is offline   Reply With Quote
Old 02-21-2009, 01:08 PM   #2
mas09ts
mas09ts's Avatar
Re: 350 Engine Pics / Air Cleaner Options
heres my custom air cleaner . . . .
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 02-21-2009, 08:25 PM   #3
jgreene0717
Jason
jgreene0717's Avatar
Jegs 14"X3" non logo with flat base. Plugged the breather hose and have open element on valve cover.
jgreene0717 is offline   Reply With Quote
Old 02-21-2009, 10:15 PM   #4
theyammieguy
accepting donations
theyammieguy's Avatar
What carb do you have on there now?
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-22-2009, 11:55 AM   #5
69gumby
69gumby's Avatar
Edelbrock #1406.
Old 02-22-2009, 12:07 PM   #6
lowriden58
lowriden58's Avatar
14x5 offset base for HEI
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 02-22-2009, 12:19 PM   #7
69gumby
69gumby's Avatar
I'm seeing everyone is using a breather in the valve cover rather than the breather through a tube into the air cleaner.
Old 02-22-2009, 05:30 PM   #8
69gumby
69gumby's Avatar
Hey all, Thanks for the ideas. I went with a K+N and installed a breather in the valve cover. In the mean time I cleaned up the old fire wall, WOW I found paint.
Old 02-22-2009, 10:05 PM   #9
jgreene0717
Jason
Good work looks great!!!!!!
Old 02-24-2009, 02:06 PM   #10
69gumby
69gumby's Avatar
I have another question. My Edelbrock #1406 carburator has two vacuum ports for the distributor. One says it's a timed vacuum the other is not. I am running a later model electronic ignition. Which vacuum port should I be using?
Old 02-24-2009, 02:38 PM   #11
jgreene0717
Jason
You should use the timed vacuum port going to distributer vacuum advance.
Old 02-24-2009, 03:05 PM   #12
3quartertime
My Mistress the Sea
3quartertime's Avatar
Cool thread!
I'll have the same dilemma when I put the 1406 on. Assuming I ever get around to it! lol...
Where did you get the K+N and how much, if you don't mind. It looks good!!!
,,,they'd look alot better as beer cans...
'71 K20 350/350 Rusty but trusty... gone
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
'95 C3500 6.5L Dually love this one!...
3quartertime is offline   Reply With Quote
Old 02-24-2009, 03:48 PM   #13
Bruce88
Bruce88's Avatar
I’m using a 65903 - Moroso low profile air cleaner with a stock 4 barrel spacer for the PCV vent tube to the valve cover.
Also thought I would try and see if using pictures that are already loaded on another thread could also be used on this thread without having to load them again and taking up server space. If you can’t see the pictures of the air cleaner there on my build thread.
Attachment 410985
Attachment 410987
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 02-25-2009, 03:44 PM   #14
69gumby
69gumby's Avatar
Bruce88, that looks nice I was about to go with the spacer on my carb but it looked to tall so I went with the breather in the valve cover. I still have the old spacer I may have to take another look at it. Oh and that's a nice looking engine!!!
3quartertime, I paid $150 for the K+N, a little pricy but at my age I should never have to buy another air filter. I was able to notice the power increase between the old 10"X2" and this 14"X3" K+N. They say I will get better milage to so I see it as an investment that will pay off.
jgreene0717 Thanks for the info. I'll move it over to the timed port.
Old 02-25-2009, 06:14 PM   #15
jholley
jholley's Avatar
You could go with one of these.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
