Leaf to Coil Swap Questions????
I know this has been asked before, I'm sure but if I wanted to convert my leaf spring rearend to coils would I have to change that crossmember under the cab or would it just bolt right up, I'll post a picture of the crossmember, I believe that the trailing arms would bolt right up to it but I'm not sure. Any helps appreciated.
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
Re: Leaf to Coil Swap Questions????
ttt anyone??
resident oilfield trash
It will bolt right up you are going to have to get a pan hard mount for the frame though is there a hole in your rear end for the panhard bar to connect to
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
I actually have all of the parts you need to do the swap including the trailing arms
So it will bolt right up, thats good. I've know where I can get the trailing arms and so forth, but if I were unable to get them, what would be your price? I would have change the rearend also wouldnt I, I mean I can get that too but it would be great if I could use my exsisting rearend.
and btw thanks for the info.
I've not checked for the panhard hole, I'll do that tomorrow.
ttt anything else I should know about?
ttt anyone? step by step instructions would be great also if they are any
thanks
