Old 12-13-2002, 10:28 AM   #1
boilrman
70 Chevy 3/4t
Unhappy master cylinder ?
I have had a spongy brake pedal for a few days and finally stopped by the parts store and they said I have a leak somewhere.
I took the lid of the master cylinder and the fluid from the front compartment started to flow out. It was full and under pressure. The rear compartment had about 1/2" of fluid in it. I refilled the rear compartment and the brake pedal has returned to what it was before.
My ? is, why was the front compartment pressurized?
I haven't pulled the drums yet to look for leaks, but I dont understand why the front compartment was under pressure.
Any help would be appreciated.
Chad
Find a job you love and you'll never have to work a day in your life.
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
Old 12-13-2002, 01:10 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Very interesting...
If it was pressurized, you'd think it would cause the brakes to drag.
No answer here...just a TTT.
Old 12-13-2002, 02:20 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
My best guess is the seal between the 2 reservoirs has failed. You are pumping the fluid from the back into the front. you will need a new master cylinder.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-13-2002, 02:51 PM   #4
boilrman
70 Chevy 3/4t
Da Burb,
My thought also was that the master cylinder was failing, but the parts store folks seem to think there is a leak somewhere.
But also I havent noticed any fluid leaking from the master cylinder before, and when I took the cover off the back half of it was almost empty. I dont see how it could be going empty unless there was a leak somewhere, but yet I am not sure how I am pressurizing the front half, unless of course like you mentioned the seals in the master cylinder bad forcing it into the front.
Unfortunately I dont have the time now to look into it for a few days, so I will just have to keep an eye on it and see how things go.
Any other ideas would be appreciated.
Kokomo,IN
Old 12-13-2002, 08:58 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
The other leak that you sometimes can't see is when the fluid is draining into your vacuum booster. All I can say is,where did the extra fluid come from in the front reservoir? If there is more there than there should be, it had to come from the back reservoir. (Unless you recently put in new pads/shoes and never checked the master cylinder fluid level)
Old 12-14-2002, 12:22 AM   #6
Longhorn Man
And if there is no booster, it'll leak into the cab down under the carpet.
Old 12-14-2002, 01:45 AM   #7
Capitol68
Capitol68's Avatar
are your brake shoes so far worn that it has used that much fluid to function,,dont know about pressure question ?
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 12-14-2002, 03:02 AM   #8
boilrman
70 Chevy 3/4t
truck has new pads on all four corners. No power brakes. was just doing some minor metal work on drivers side floor and saw no leaks(I had the rubber pulled all the way over to the gas pedal)
It is my '70 3/4t, so drum brakes all around. I replaced one front and one rear wheel cylinder that was leaking when I did the brake job.
Kokomo,IN
Old 12-14-2002, 09:50 AM   #9
Capitol68
Capitol68's Avatar
sometimes when u do a brake job and the shoes were worn bad and u added fluid previously it took up the added space. when u replaced them the extra fluid had to go somewhere, hence seemingly more fluid. I would just keep an eye on it, make sure shoes are all adjusted up.
'68 Fleet LWB
orig 307 .030 over
orig. stock TH 400.
Albert Pine
Old 12-14-2002, 05:12 PM   #10
tai
tai's Avatar
tai71k20
dont know about the front presure, but sounds a lot like the 30 seconds before my master cylinder went out
tai is offline   Reply With Quote
