Old 02-21-2009, 08:30 PM   #1
cobrajet21
cobrajet21's Avatar
Switch to a Big Block
Can you put a big block in a truck with a low hump cab or do i need to change to a high hump? What other changes or problems would i run into?
cobrajet21 is offline   Reply With Quote
Old 02-21-2009, 08:44 PM   #2
Re: Switch to a Big Block
It is probably better that you do put in a high hump, but I do not thing it is mandatory. I thought some one said some came with low hump, but I cannot remember for positive.
Old 02-21-2009, 08:48 PM   #3
spinning wheels
spinning wheels's Avatar
High humps were 4X4, 4 speed, or Turbo 400s.
You can put a big block in a low hump, the engine does not come in contact with the cab.
The humps were for clearance due to the trannys.
If your tranny hits the hump, you can always cut and modify your cab.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-21-2009, 09:03 PM   #4
cobrajet21
cobrajet21's Avatar
i am going to use a 700r4. will that make a difference?
Old 02-21-2009, 09:18 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Just to clarify, I have a TH400 in my '69 with a low hump.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-21-2009, 09:31 PM   #6
Security guy
Security guy's Avatar
I've got a big block and 700r4 with a low hump floor. It fits great. Some people have said that it will hit, but i think thats because of cab mounts being worn out. As long as you have good mounts for everything, it should go in no problem. The only trouble I had was getting the motor and tranny in the right place. At first, my mounts were to far forward, so I had to move my mounts back a little. I did use all factory holes for mounting, so it shouldn't be a big deal.
Security guy is offline   Reply With Quote
Old 02-21-2009, 11:12 PM   #7
68350
68350's Avatar
We had a 402/400 in a 72 sb. The only thing I recommend is to put new cab mounts on(doesn't hurt anyways to change) except it might misalign the panels, so it might turn into a larger project than thought. i'm not sure on the dimensions of a 700r4, but isn't it the same size as a th350? if it is, it should work out no problem.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 02-21-2009, 11:44 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
where did the misconseption come from that says TH400 trucks had a high hump? I see it posted on here all the time.
High hump floors came in 4x4 trucks, 4 speed trucks, and big blocks with TH400.
A handfull of oddballs came out with the wrong floors, I have a 305 V-6/TH400 with a high hump, and there's beena couple bb/th400's documented on here with a low hump.
If you have good cab mounts, you should be fine.
Old 02-22-2009, 12:03 AM   #9
67/72junkie
Longhornman has hit the nail on the head,72,000 plus post .Thats alot of time on the board longhorn!I don't think he has missed very much.
67/72junkie is offline   Reply With Quote
Old 02-22-2009, 01:52 AM   #10
spinning wheels
Longhorn, you may be right. What GM has put out as model info, does not always end up being correct info. For example, I have a 70 RS Z28. According to GM, no A/C was available for my model year. Yet, I have factory installed A/C. Exceptions seem to be the norm when talking about GM products. Could be one of the reasons GM is on life support? I bet Honda has never screwed up on their info
