Old 12-13-2002, 10:33 AM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
H-pipe?
I'm thinking of adding a H-pipe to my truck. I have headers, dual 2.5" pipe, and 40 seires Delta Flow flowmasters on it. The exhaust ends above and infront of the rear axle. It sounds pretty good right now, and is plenty loud. Will the H-pipe make is sound any better, louder, or quieter? Also, would it give me a little gain in horsepower?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-13-2002, 10:47 AM   #2
crazy longhorn
Fabricate till you "puke"
The h pipe will quiet the system just a bit, & it will have a more "tuned" sound. It will add some power to the low & midrange, & shouldnt hurt the topend power. if you get some cheap paint, & squirt a line on the pipes after the header collectors, then run it for a while you will be able to see where the paint stops burning. That will be the optimum point to install the pipe. good luck.....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-13-2002, 11:34 AM   #3
RON WOODGEARD
Resident Young Old Dude !
Crazy AL has it... The ideal way to do it, is not to run a "H" pipe. It's to bend the exhaust tubing until it just touches each other, Then cut where they touch, and weld them together. The idea behind it is it will smooth out the sound waves and break up in the exhaust the off set firing order from the engine. It REALLY makes a difference in the sound, Smooths and toughens it. I seen a very nice kit in one of the parts catalogues, very "SANO". It was rather expensive though.
RON WOODGEARD is offline   Reply With Quote
Old 12-13-2002, 11:48 AM   #4
crazy longhorn
Yes, the X pipe is newer technology, & a better way to go! they will be a little harder to fit, especially to an already existing system.....but from what i have read, worth the extra cash/trouble.
Old 12-13-2002, 08:25 PM   #5
mikep
Used to have a truck
mikep's Avatar
I added an H pipe to a 2 1/2 inch exhaust system with 40 series flowmasters dumping at the axles once out of a fairly large cammed motor. Had it removed a week later. Hated the sound! It took a nice throaty pulsing sound and turned it into a constant drone.
No truck :-(
mikep is offline   Reply With Quote
