just got a 81 crew cab
i just traded for a 81 crew cab 3/4 ton and i want to build a 1/2 ton short wheel base i know there are threads on here but i can seem to find them on were to cut both of the rear frame's and stuff and what all do i need to change the front end to 1/2 ton thanks for any info
Re: just got a 81 crew cab
Search for Ojoes Crewcab build . It will be some useful reading for you . Be sure to post pics of your progress so we can all enjoy .
Frank
Born and proudly residing in a Red State ! |
frank i will just as soon as i start on it i looked at ojoes but didnt see were it said were to cut and how much
#4 | |
Luv the Crewcabs
I Used the Info on a 86 3/4 ton Crew stepper that im currently building, Here are a Couple Pics of my Project........... Good Luck with your Project & Post up some Pics when you get a Chance. Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
thanks tomanytoyz so on the front end i can keep the cross member and just use the 1/2 ton upper and lower a arm's and spindles and again thanks guys
tomanytoyz thats going to be a cool step side when your done
Superbad
That step side is cool toomanytoyz, I haven't ever seen a Chevy / GMC crew cab step side before, I seen lots of Dodge & Fords. But if I was going to do one I'd stretch the 1/2 ton frame & box it in. The 3/4 & 1 ton frame hang down to low for my liking.
