profeshinaly unimployed
idea
ok well i found out my truck will start if a put a little bit of fuel into the carb but now im wondering is there a way that i can wire a momentary switch up to the fuel pump to like prime the engine
"having mud flaps is like asking for a smaller trophy" |
Re: idea
Why not fix the problem? It sounds like the accelerator pump on your carb (asuming it isn't fuel injected) is bad. A vacuum leak could be part of this issue, as could ignition timing/plugs/wires/cap & rotor, ect.
1970 long fleet, 355 4 speed, primer, walnut goodies |
The One And Only !!!
Re: idea
Unless you've added a electric fuel pump which should be activated soon as the key is turned on, It will be hard to hook a momentary switch to a mechanical pump.
Sounds like the two welch plugs in the bottom of the float bowl, They start leaking fuel out of the bowl into the intake when the engine sits for long periods (over night). Then the engine must be cranked over enough to re-fill the fuel bowl before it will start. These leaking welch plugs can also cause bad fuel mileage. The fix is remove the carb and cover these two welch plugs with JB-Weld letting cure then re-install.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#4 | |
Re: idea
Re: idea
Well,
With the rest of the story now revealed, Replace the accelerator pump as shadetree suggest.
Re: idea
now the accelerator pump is just the fuel pump right?
GM Addicted
Re: idea
The accelerator pump is the pump in your carburetor. What kind of carb are you running?
Re: idea
q jet
GM Addicted
Re: idea
Go down to a parts store and get you a rebuild kit for your carb. Or simply just get the accelerator pump. Or if you have the money it is worth getting an edelbrock carburetor they are great carbs.
Kid's Mechanic
Re: idea
Re: idea
when i pump the gas all the lincage and stuff to the accelerator pump moves but like still i see no fuel goin into the carb
Happy to be here
![]() Join Date: Mar 2000
Re: idea
Once again, it "sounds" like the accelarator pump in the carb. If you don't think you are capable of replacing the pump, see if you can't find someone local that can help.
We don't mind giving advice, but you should be willing to accept it if you ask.... ![]()
#13 |
Re: idea
Also, Take all the numbers off your carb with you to get the proper kit/pump.
#14 |
Re: idea
i wasnt not accepting it its just powerdriver asked in that pic think if the linkage was good
#15 |
Kid's Mechanic
Re: idea
If you try to rebuild yourself here's a link http://www.4wheelnoffroad.com/qjet.html
#16 |
Re: idea
mine was doing the same thing, put a rebuild kit in it, does fine now.
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
#17 |
Kid's Mechanic
Re: idea
Poke, the priming idea is a bad one.One backfire and you have a fire that you may not get out.I hope you don't take that the wrong way,just to many things to go wrong.Don't want anybody hurt.
#18 |
Re: idea
oh since all i have to do is rebuild the carb then i don't plan on doing this idea
#19 |
Another Day, Another Dollar
Re: idea
you'll shoot your eye out kid
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
#20 |
Happy to be here
Re: idea
That too funny.
Let us know if you need any input Poke.
