Old 02-22-2009, 04:25 PM   #1
renagadebee34
cant find the right intake!?
ok i thought i had a 1996 to 1997 5.7 liter 350 with vortec heads! so i bought a intake to fit that but its not even close! and the intake that was on my 305 wouldnt fit either! it was close but the 2 center bolts on each side go straight down instead of diagnal and my truck is a 1986. so what do i need to get? sorry if its confusing. Thanks zack
girls love guys like me!!!!!!
renagadebee34 is offline   Reply With Quote
Old 02-22-2009, 04:54 PM   #2
Primer70
Superbad
Primer70's Avatar
Re: cant find the right intake!?
On the 1996 - 2000 Vortec heads they did away with the two center bolts for the manifold & the remaining bolts go straight down. The 1987 - 1995 heads two center bolts for the manifold are at a slight angle, almost sraight down. The 1986 & older heads two center bolt for the manifold are at the same angle as the other manifold bolts. So if your two center bolt for the manifold are almost straight down you need a manifold for 1987 - 1995 heads.
If you are unsure of what heads you have post the casting numbers & I'm sure someone hear can tell you what year they are for you.
Primer70 is offline   Reply With Quote
Old 02-22-2009, 04:59 PM   #3
renagadebee34
ok ill try to do that thanks for ur help the motor is a crate motor then put in a 1989 comaro and then now my truck and i didnt get enough information from the guy i baught it from! rookie mistakes i guess thanks again
Old 02-22-2009, 05:08 PM   #4
renagadebee34
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
would this be to extreme for my truck? would it work?
Old 02-22-2009, 05:54 PM   #5
Primer70
Superbad
Primer70's Avatar
3,000 & up RMS, yeah to extreme for a truck, especially if the rest of the engine is stock. I'd recommend an Edelbrock Performer, Prefromer RPM or a Weiand Action Plus intake manifold.
