Old 02-22-2009, 04:30 PM   #1
Low84
Low84's Avatar
Removing Heads, need help
I finally got my hands on a brand new set of replacement heads. I got the manifolds off and most everything else too. I just realized I have no clue how to remove the distributor
How do you remove the distributor from the manifold?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 02-22-2009, 04:33 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Removing Heads, need help
There is one bolt to the left of the distributor (as you are looking at it from the front of the truck). That bolt goes through a metal clamp that holds the distributor in. Loosen the bolt, slide the clamp back (or pull it out all-together), and then pull the distributor out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-22-2009, 05:33 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Mark the distributor housing where the rotor is pointing before removal, Don't turn the engine over with the distributor out. Then all you have to do is align the rotor to the mark you made and re-install it into the engine.
Doing this eliminates having to re-time everything.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-22-2009, 05:48 PM   #4
Low84
Low84's Avatar
Thanks for the help guys, it's out already. I'm hoping the engine isn't in too bad a shape
Old 02-22-2009, 05:54 PM   #5
hotrodhomi
hotrodhomi's Avatar
clarification- you will still need to time it, but this will save you the trouble TDC or putting it back 180 degrees out. Putting it back in will get your very close to the original timing (whatever it was before removal)
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-24-2009, 02:48 PM   #6
Low84
Low84's Avatar
It just occured to me, but will simply replacing the heads and gasket solve the problem of a blown head gasket?
I don't have to send the block to get resurfaced right? (please say no )
This is as far as we got on Sunday:
and I do have brand new heads and gaskets ready to go in:
I'm kind of in a bind, I have no running vehicle right now and really need to get this thing up and running ASAP
Old 02-24-2009, 02:59 PM   #7
78 Chevyrado
yes, this will fix you up, the block should be fine, just make sure the block is extremely clean-as-you-can-get-it and smooth where the gasket goes and use a quality gasket.
78 Chevyrado is offline   Reply With Quote
Old 02-24-2009, 08:15 PM   #8
old Chevy guy
old Chevy guy's Avatar
I had one once that leaked for a while before it became undrivable,hydrolocked one day, I had the heads checked and surfaced but the block was a little pitted.It turned out alright though it didnt wind up leaking,but Iwas a little scared.It was a P,I,T,A to do ,it was in a van.
old Chevy guy is offline   Reply With Quote
Old 02-25-2009, 04:01 AM   #9
Low84
Low84's Avatar
Thanks for the reassuring words. Will using a gasket scraper suffice? I'm guessing a light sanding would probably make matters worse?
I bet, the family car used to be a Chevy Goodtimes Van with a 350. I was too small work on anything then, but I still remember how tight the engine sat in there, that and the fact that half of it was recessed into the firewall
Old 02-25-2009, 09:49 AM   #10
Storm Chaser
Storm Chaser's Avatar
I bet that thing was DIN-O-MITE!
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-25-2009, 11:18 PM   #11
73chevyman
73chevyman's Avatar
looks like your doing the cam to heres a couple of videos for ya
hope this will help you out
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 02-25-2009, 11:20 PM   #12
73chevyman
73chevyman's Avatar
by the way if your doing the cam take a look at you timing chain might want to replace it if your that far
73 C10 Fleetside
Old 02-25-2009, 11:33 PM   #13
78 Chevyrado
Yeah a scraper will do fine, just don't gouge the surface. I wouldn't sand it, it may cause surface irregularities. The surface won't LOOK clean and new, even if it is smooth enough. just feel it with your fingertips, they'll tell you if you missed anything.
Old 03-09-2009, 03:21 PM   #14
Low84
Low84's Avatar
Alright guys I had my birthday get in the way this weekend so I didn't get to put in work on the truck so I'm trying to make up for it today.
I already taped off the ports on the intake side of the heads to prevent debris from getting in. I also bought these:
For the head gakets (copper)
and one "Super Blue Gasket Maker" for the intake manifold gasket and to help seal at the front and rear part of the manifold.
Now here is my question, do I just aplly the Gasket Shellac on both sides of the gasket and bolt the head to the block? Will this be enough? Or should I also put some of the Super Blue (on the block side of the gasket) on there for a better seal?
Old 03-09-2009, 07:09 PM   #15
cjracing15
cjracing15's Avatar
Do not put ANYTHING on the block surface after you clean it. Install the head gaskets dry. There should be dowel pins to hold the head gaskets in place.
As for the intake I personally use the black silicone because it just looks better to me. When you put your intake gaskets on all you need is to put enuff silly on the heads to hold the gaskets on so you can install the intake. When you buy your gaskets it will come with end gaskets for the intake do not use them. Run you a beed of silly along the ends of the block and make sure you overlap the ends of the intake gaskets. This shoud fix you right up. Take your time and you will do fine.
Good luck.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 03-09-2009, 07:36 PM   #16
LONGHAIR
"It depends" upon how badly blown, where it is blown, and how long it ran that way. I have seen head gaskets blown out between cylinders where it was driven quite some time before the tear-down. This can erode the block or the heads or both.....maybe not even leaking water.
Look for charred/black crispy places, especially between the cylinders.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-09-2009, 08:48 PM   #17
Low84
Low84's Avatar
Good luck.
I just saw that a couple hours ago, I feel retarded now Thanks for the advice, it's getting dark out and I'm calling it a day.
Old 03-09-2009, 08:56 PM   #18
Low84
Low84's Avatar
I didn't travel more than 10 ft after the head gasket completely gave out. The family mechanic saw me working and stopped by for a few minutes. Turns out the heads aren't cracked but a valve was. He saw the engine through and said the engine appears to be in good condition and should be fine after the re-assembly.
I'm really hoping so
Old 03-09-2009, 08:57 PM   #19
cjracing15
cjracing15's Avatar
Do not feel retarded, you will never know if you do not ask . But do not put anything on your head gaskets at all. How far did you get?
The fleet
1977 SWB stepside
1949 Chevy truck
Old 03-09-2009, 09:14 PM   #20
Low84
Low84's Avatar
...right at applying that shellac thing between the heads and gaskets
It was kicking my ass cause it kept moving around on me, so I held it in place enough for it to dry slightly and then carefully placed that surface down on the work table to let them dry in place. I figured I wasn't going to get the truck ready for tomorrow so I'm fixing up the car instead.
Old 03-09-2009, 09:22 PM   #21
cjracing15
cjracing15's Avatar
Does it have the dowel pins in the block?
The fleet
1977 SWB stepside
1949 Chevy truck
Old 03-09-2009, 09:50 PM   #22
Low84
Low84's Avatar
Yup
Old 03-09-2009, 10:13 PM   #23
cjracing15
cjracing15's Avatar
Alrighty then. I guess I have been lucky and never have had problems with the gasket moving around on me if I had the dowels in the block.
Good luck on it.
The fleet
1977 SWB stepside
1949 Chevy truck
Old 03-10-2009, 03:41 PM   #24
Low84
Low84's Avatar
Good luck on it.
No you're right. But I jumped the gun trying to get the truck ready and put the gasket on the head INSTEAD of putting it on the block first.
Old 03-10-2009, 06:33 PM   #25
cjracing15
cjracing15's Avatar
OH it is now all becomming more clear now.
The fleet
1977 SWB stepside
1949 Chevy truck
