Will a bench seat out of an 85 pick up fit in a 67-72 truck or would you have to modify the bolt holes?? Are there any other years that would fit?
If your not living for something, your dieing for nothing... |
Re: 85 bench seat in a 67-72?
Anybody?
you can make it work but youll have to modifry the brackets and itll sit kinda high
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Mine is from the 80s I think and it is mounted with new holes. No big install tricks just holes that weren't there before. I found a stock seat that I want to redo and install in mine. I think I will get better leg room and sit a little lower. You can see the stock bolt location under the seat.
69 sweet long fleet, David |
its all about the +6 inches
the 73 - 87 truck seat won't fit unless you install the newer seat onto the 678 - 72 tracks.
The 73 - 87 floor is not flat. Gumby's seat shown above is out of an 88 - 98 truck Last edited by Longhorn Man; 02-23-2009 at 12:08 AM. |
Active Member
![]() Join Date: Jul 2007
I used the back seat of an 86 quad cab. The front and back were very similar but the back one was in almost perfect condition. I'm thinking of redoing my original bench seat and had to put in a temporary seat.
I used the bottom brackets off a spare original seat that I had. Redrilled some holes on the new seat bottom and with a little bit of persusive engineering came out pretty good. |
Put one in my old truck once, changed the rails and also had to cut the knob off the lever that tilts the back of the seat forward. The knob hit the gas tank.
72 chevy 3/4 ton 4X4 |
67-72 parts collector,…
![]() Join Date: Nov 2002
like 69gumby said,... the 88-94 chevy/GMC truck seats will work fine. This is one I have on the board for sale.
http://67-72chevytrucks.com/vboard/s...d.php?t=328019
