Tailgates without Chains
I'm putting my bed back together & don't want to use the stock chains & hooks.
What after market or OEM parts have you guys adapted to fit your 64 - 66 fleetsides? I plan to use stainless barrel slides to secure the gate but what type of flat bars or cables work best? Was any cutting of the tailgate required? |
Registerd User
Re: Tailgates without Chains
Welcome. Check out my build thread. I got an aftermarket tailgate from mar-k. Hope you get the info you want.
That's really trick set up but at nearly $600 w/o shipping is beyond my current budget. It does look great though as does the rest of your project. You are doiing some gret work.
MAR K sells the slide barrels & chain eliminators for $150, I was hoping to find an even lower cost option. ANy ideas or pictures would be great. Thanks |
Registerd User
I've seen people use latches simular to the ones mar-k sells but made for the doors on sheds and such from the ho depo or lowes and I don't see why the linkages from a square body wouldn't work.
This is the hardware from a late model S10. I bought a wrecked tailgate for 5.00.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
502TriPower, that is the solution I was looking for. That cost is more in my very small ballpark.
Did you weld the MAR-K type slide bolts to the S-10 latch? Does the whole latch unbolt & slide out from the end of the tailgate? Do th cables hide in the space between the tailgate & the bed or do the cables store in the bed? Thanks, Blue666 |
#7 | ||
502tripower,
that looks really nice and very well done. I take it that you just pull those tabs of bolts inward to get the latches to release? -W some more options to look at: http://www.wow-products.com/ products / tailgate ---- http://www.persh.org/pickup/IdeaPage.htm look under Tailgate & Beds ---- -W Last edited by Woogeroo; 02-22-2009 at 09:31 PM. |
#9 | |
I used latches and cables from Frantsen. They have bolt on or weld on. Give them a call, real easy to get along with........
http://www.frantsen.com/chevygmc.html |
http://www.mar-k.com/Catalog/catalog.aspx
$75 from Mar-K. Latches up to you. I am taking the hidden one off and going with cam locking clam style. http://www.horkeyswoodandparts.com/page17.html They also have hidden latches and supports.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
