Old 02-22-2009, 06:09 PM   #1
84step
New Carb?
So i have been having troubles with my old q-jet latley and have convinced my parents to get me a new carb for a grad present. My question is what would be the best route to go iam thinking of either an edelbrock or a Holley street avenger either way iam thinking around a 650cfm, the engine is a 350 btw.
"All Throttle No Bottle"
1984 C10 Stepper
84step is offline   Reply With Quote
Old 02-22-2009, 06:11 PM   #2
enaberif
Re: New Carb?
Most people seem pretty happy with the 1406 Edelbrock
enaberif is offline   Reply With Quote
Old 02-22-2009, 07:03 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: New Carb?
I have a Demon that came on my B/B that uses Holley float valves, It would out of the blue start flooding going down the road. I strip cleaned the carb and installed new Holley float valves and it still floods. I will be ordering a new Edelbrock soon.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-22-2009, 10:30 PM   #4
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: New Carb?
i would go with a holley its more of a user friendly carb and the parts are easily mixed and matched
staggerd86c-10 is offline   Reply With Quote
Old 02-22-2009, 10:36 PM   #5
84step
Re: New Carb?
I talked to my friend who knows alot about carbs etc and he suggested to me that i get a holley street avenger 650cfm i think thats the way iam going to go.
1984 C10 Stepper
Old 02-22-2009, 11:03 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: New Carb?
Personally I suggest you get your hands dirty and try to rebuild the Q-jet. Then you could get something else for Graduation...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-22-2009, 11:37 PM   #7
hotrodhomi
hotrodhomi's Avatar
Re: New Carb?
Not a bad suggestion. Rebuilding and tuning is the best way to learn how carbs work.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-23-2009, 02:16 AM   #8
Primer70
Superbad
Primer70's Avatar
Re: New Carb?
Q-jets are just about the easiest carbs to rebuild, and cheap to rebuild too. I'm considering running a Q-jet on my Suburban with the new engine.
Primer70 is offline   Reply With Quote
Old 02-23-2009, 02:33 AM   #9
78 Chevyrado
Re: New Carb?
I've had 5 1406 edelbrocks on five engines and love em. they all work well, just pick the one you can work on the easiest.
78 Chevyrado is offline   Reply With Quote
Old 02-23-2009, 12:34 PM   #10
60ratrod
yes, i do
60ratrod's Avatar
Re: New Carb?
my vote is for an edelbrock. you don't have to tune an edelbrock as often as a holley
60ratrod is offline   Reply With Quote
Old 02-23-2009, 01:29 PM   #11
Storm Chaser
Storm Chaser's Avatar
Re: New Carb?
I've had Q-jets and Holleys in the past, then a few years ago I bought my first Edelbrock... and haven't looked back since. When it comes to carbs, my opinion is Edelbrock all the way. IMO, they are much more user friendly than a Holley.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-23-2009, 02:01 PM   #12
Damien
Damien's Avatar
Re: New Carb?
I would rebuild the Qjet as long as it is not the computer controlled version.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 02-23-2009, 02:10 PM   #13
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Re: New Carb?
I dunno where you all found reliable Edelbrock, i pulled a 2 yr old 650 off my truck (motor is a 355 sb) and replaced it with a new holley 680 about a year or so ago, the Edelbrock was a piece, i love the holley and would never consider going back.... not to mention my truck is much happier, and runs infinately better also
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 02-23-2009, 04:12 PM   #14
Storm Chaser
Re: New Carb?
I don't know, they just work... no pwer valves to blow out, no leaky gaskets below the fuel level line, easy adjustability...
You mentioned pulling one off and replacing it- maybe there was something wrong with that particular one, who knows. But as someone who has owned many different vehicles with many different carbs over nearly 40 years, I'd have to say for a mild street engine (meaning not a race car), my prefs would be in this order: EFI, Edelbrock, a Q-jet in good condition and tune, then Holley. Again, just my opinion. I personally find the Holleys to be a bit finicky, bordering on drama queen, for something you have to depend on every day.
1988 R2500 Crew Cab
Future plans-
Old 02-23-2009, 04:57 PM   #15
Alex1
Alex1's Avatar
Re: New Carb?
Holleys nolonger have PV issues BTW.
Go Holley and don't look back -Sooo easy to work on.
Alex1 is offline   Reply With Quote
Old 02-23-2009, 06:55 PM   #16
84step
Re: New Carb?
Thanks for the advice guys I think iam gonna go with the holley, if i have any problems iam blaming you guys hahaha i also have a friend who has alot of mechanical experienc and he tells me the same thing that the holleys are good carbs and easy to adjust, imo i think i will remove the q-jet learn a little more and attempt to rebuild it and perhaps sell it later on.
1984 C10 Stepper
Old 02-23-2009, 08:20 PM   #17
thefatguy
Re: New Carb?
I've got one of each. Actually, one is a rebuilt Carter AFB. So far, the Carter has been bolt-n-go (Q-jet replacement on a 454). The Holley is on a troubled 292, and I can't possibly blame it, but it's been a real bear to get to know (more my fault than it's). My buddy who builds dragboats likes both of them just fine.
1978 Silverado Big 10 - "The River Runner"
1969 GMC C/10 - "The 2008-09 Winter Project"
thefatguy is offline   Reply With Quote
Old 02-23-2009, 09:03 PM   #18
Pyrotechnic
Pyrotechnic's Avatar
Re: New Carb?
It's all personal preference. Each carb has it's pro's and con's.
I personally like the Carter AFB (Edelbrock) design.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-23-2009, 09:18 PM   #19
Restrorob
Restrorob's Avatar
Re: New Carb?
BINGO !!!
Since I've been left on the side of the road a few times removing and re-adjusting float valves I want something other than Holley/Demon....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-23-2009, 09:25 PM   #20
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: New Carb?
I run a 1406 on my ZZ4. No problems. Easy carb to tune with a vacuum guage. Mechanical secondaries are a slight disadvantage.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-23-2009, 10:01 PM   #21
Bow Tie Scottie
Bow Tie Scottie's Avatar
Re: New Carb?
O.K. y'all, I've been away from here awhile. Last Summer I had my Q-Jet carb rebuilt. Since then after one minor adjustment (leaned out), my '86 C20 runs much better and on certain pleasant weather days it really shows. If interested here is a link that may help make a more informed decision:
http://cliffshighperformance.com/
Other than those 2 cents I looked into almost going the Edelbrock direction!
BTW, Chevy 350, engine VIN code "M"
Bow Tie Scottie is offline   Reply With Quote
