Old 02-22-2009, 06:51 PM   #1
goldengoat2
Looking for drive shaft for my 67 4x4
I changed my rear axle to a 14 bolt in my 67 3/4 ton 4x4 and my stock shaft is too long and can't be shortend and balanced because of a dent. I need one 37.5" center to center, is there a correct length crossover in the junk yard that I can look for. Thanks for any help.
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 02-22-2009, 07:46 PM   #2
CPNEJR
CPNEJR's Avatar
Re: Looking for drive shaft for my 67 4x4
if you find a driveshaft that is longer than what you need that is in good shape you can have that cut and balanced. it's a lot easier to have a shop make it the size you need than hunting for a specific driveshaft
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 02-22-2009, 08:58 PM   #3
LONGHAIR
Just because it can't be shortened does not mean that they can't re-tube it. If the ends are good it would still be cheaper than re-working a junkyard unit.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-22-2009, 09:35 PM   #4
goldengoat2
I may try that route
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
Old 02-22-2009, 10:13 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
be sure to take the shop both pieces of the driveshaft if its 2 piece driveshaft, you cant ballance just one piece. dont be suprised if the slip and stub in the center are worn out $$
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-23-2009, 06:50 PM   #6
goldengoat2
Getting it retubed , thanks
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
