02-22-2009, 08:08 PM | #1 |
Timing Marker
Is this at zero? Or is it all the way to the left or ???
It's emabarassing that I have to ask this, but I've been working on Buick v6s too long. I'm about to post another embarrassing thread--stay tuned.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
02-22-2009, 09:33 PM | #2 |
Re: Timing Marker
yes thats zero
02-23-2009, 08:35 AM | #3 |
Re: Timing Marker
looks like it to me. Pull the number 1 plug and stick a stiff piece of wire in. The wire should stay at the top of the hole. That's d be a way to ensure your mark is accurate. Could even pull the drivers side valve cover and check the rocker arms, if you can move them- you're at #1 tdc
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
02-23-2009, 10:10 AM | #4 |
Parts and more parts
Re: Timing Marker
I think that if you remove the rest of the paint on the tab. You will see the numbers for the timing marks.
