Old 02-22-2009, 09:45 PM   #1
b00sted
b00sted's Avatar
What options for steering coluum?
I was wondering what my options would be on a coluum? I see the new ones are $500 and up and was hopeing that there was a scrap yard solution. Truck has a 77 camaro front clip in it with powersteering... But a terrible looking coluum...
Would liek to get one from a car to put in it but do not have a clue what to look for... A 500 dollar coluum is not in the budget right now.. You can see somewhat of what it is in the truck now below... The ad on turn signal box does nothing for me... Truck is an suto...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 02-22-2009, 10:43 PM   #2
blackdiesel
blackdiesel's Avatar
Re: What options for steering coluum?
late 60's early 70's chevy van tilt is one of the best choices. What ever you use don't get one with a key in it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 02-23-2009, 12:04 AM   #3
JML55
JML55's Avatar
Here mine 85 Chevy van, you get ign switch and tranny gear selector, cruise and intermitent wipers. The steering wheel is early 90 Blazer.
Name:  nov 30 2008 002.jpg
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 02-23-2009, 01:11 AM   #4
OrrieG
OrrieG's Avatar
I used an 82 Eldorado because it is tilt telescope, has the dimmer, locking ignition and cruise (future possibility) and is only 30" which reduces conflict with exhaust maniford. I also wanted the shift on the column to keep the floor and third seat position clear. Heres a photo, I will eventually change the wheel.
OrrieG is offline   Reply With Quote
Old 02-23-2009, 08:42 PM   #5
blackdiesel
I never did like the dimmer on the column because I always got my foot hung in the steering when i met a car... Very dangerous!
Actually, i like to drive old vehicles because they look old. The dimmer in the floor is much easier for me because i either have one arm out the window, or the other arm around a girl (not at the same time, lol) and the key in the dash is just where it should be. Looks much better where it belongs
In my opinion, of course
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 02-23-2009, 11:01 PM   #6
mr48chev
mr48chev's Avatar
Actually a 71/71 Pickup column should fit in there and look pretty clean. If you are running a floor shift the columns out of the 4 speed trucks are really clean.
Turn signal switches are still inexpensive and easy to get and wheel adapters will allow you to put most any custom wheel on one.
The Chevrolet van tilt columns w/o the ign switch are real popular and also pretty clean for a tilt.
Old 02-24-2009, 07:28 PM   #7
54 jimmy
54 jimmy's Avatar
i am using a 68 c10 steering column and it fits the stock clamp/bracket under the dash and looks great. i picked mine up for $20.00 and needed to clean and paint it.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 02-25-2009, 01:42 AM   #8
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i am using the tilt column from the 77 nova that i took the clip and rear axle from
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 03-02-2009, 01:53 PM   #9
Sinisterspeed
Sinisterspeed's Avatar
Well, I just built one for this same reason. I didn't want the key on the column and the 67-72 column I had was way to long and reached in behind the frame. (might be ok if your using a rack & pinion. But, doing the Power Steering swap on my dads 55 I needed a column that would stop close the F/W this way the auto shifter woudn't contact the exhaust manifold or valve covers. So because the steering box is outside the frame a rag joint cant be used (as a u-joint) And the ford column has a rag joint right at the end. I removed the shaft from the column from both of the column I had laying around and welded a piece of the chevy shaft on the end of the now cut off ford shaft. It's clean its exactly what we wanted and for me it was free.
So, if your looking for the same thing I was as a finished product, you can use one out of an late 60's early 70's ford. You just have to modify the shaft. The column Lenth is 32" instead of 35
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 04-02-2009, 10:35 PM   #10
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
seems to me that then 67-72 column would be to long on the inside of the cab. However, i think it would look great since it has no shifter or ignition.
i think i'm going to have to go junk yardin' to find something i like.
anyone else have some suggestions? In my case i'm running a rack and plan to have 2 u-joints in the shaft to make it work.
IvelDesigns is offline   Reply With Quote
Old 04-03-2009, 08:01 AM   #11
blackdiesel
I just cut 5" out, and shaved the shifter off of a late 60's car column to put in my old couple. If you like the column don't worry about how long it is. Now, one of the newer ones would be a different story, but I like the no key look.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 04-03-2009, 03:48 PM   #12
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I liked a shortened van column myslef. Have a look at the pics I put up today in my build thread.
ChuckDriver is offline   Reply With Quote
Old 04-17-2009, 12:08 PM   #13
Tomb23
Just a few shots of a SO FAR project! Relocated Tank / Installed Disc Brakes / Big Surprise to many ? Original GMC Power Steering, with stock 2 piece column
Tomb23 is offline   Reply With Quote
Old 04-17-2009, 10:49 PM   #14
Scottshotrods
If you are looking for a
tilt steel column we sell
Ididit and have them in stock Starting price is $300.00 plus ups and come with a lifetime gaurantee call us up
\(805)485-0382
www.scottshotrods.com
Thankyou,
Justin
Scottshotrods is offline   Reply With Quote
Old 04-18-2009, 12:01 AM   #15
IvelDesigns
\(805)485-0382
Thankyou,
Justin
just ordered mine from Jeph on Thursday. got a 30" plain steel with tilt. I'll post pics once it gets here.
Old 04-18-2009, 12:15 AM   #16
Scottshotrods
Thankyou for the order your column shipped today by
ups.
Justin
Old 04-18-2009, 01:09 AM   #17
IvelDesigns
It's off topic from this thread, but what gas tank is that that you have there?
Old 04-18-2009, 04:03 AM   #18
bobinbc
bobinbc's Avatar
I'd like to know too. Mustang or Cougar?
bobinbc is offline   Reply With Quote
Old 04-18-2009, 08:05 AM   #19
GRIMSS
GRIMSS's Avatar
There's another topic on tank and he said it's a '70 mustang.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 03-15-2011, 02:24 PM   #20
Maximus
Maximus's Avatar
You can just get one of the units that are in my Caddy (Factory Option in 56)
Autronic Eye... Automatically dimms high beams when the sensor sees oncoming headlights
Maximus is offline   Reply With Quote
