Old 02-22-2009, 10:13 PM   #1
blue74chevy
need help with my truck!
A couple of weeks ago I started my truck and it ran for about a minute and then it slowly died. I tried to start it again and it was not getting any fuel to the carb, So I finally got to replace the fuel pump today and it was still not getting any gas after many times of trying to start it, it has dual tanks so I checked the valve and accidenly broke it so I replaced it and it still will not start. Any ideas?
it is a 74 k20 with a mechanical fuel pump
blue74chevy is offline   Reply With Quote
Old 02-22-2009, 10:28 PM   #2
f.monroe
f.monroe's Avatar
Re: need help with my truck!
Assuming you have a stock quadrajet carb and fuel line , Sounds like the fuel filter is clogged . Take the fuel line loose at the carb and turn the engine over . Point the line into an empty plastic bottle and see if you have fuel to that point . If so the in carb filter is clogged or the needle and seat is stuck .If you do not get any fuel flow with the line disconnected , you need to look at the rubber lines from the tank to the hard lines . Mine dryrotted and started sucking air . That was on a daily driver . They just had gotten old .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-23-2009, 12:59 AM   #3
blue74chevy
It is a 4bbl edelbrock it has a clear fuel filter so yo can see when the gas starts pumping, The lines look ok and it was getting gas to valve under the truck when I replaced it
Old 02-23-2009, 02:05 PM   #4
blue74chevy
if I need to replace the rubber fuel lines under the truck do I need to drop the tanks to replace them?
Old 02-23-2009, 06:10 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Either drop the tanks or un-bolt the bed and raise it, Since you are dealing with two raising the bed may be easer.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
