Old 02-22-2009, 10:33 PM   #1
jdurant
I'm elbow deep.What should I do while I'm here?
Here's my other embarassing thread/novel.
I really haven't worked on carbureted small blocks much. This is actually the deepest I've gotten into one. My truck has never really needed much attention and tbi anyway. And as much as I love these trucks, until recently, haven't had the urge to modify the powertrain. I'm getting there though. They've alway played the most significant role as my daily driver/ cruiser. That being said-I'm nearly 100% that I blew the intake gasket on the Blazer last week. I've always told myself that when something happens to the drivetrain I was going late model fuel injected. But another project has caught my eye, so I think I am going to be selling the Blazer real soon.
It is an 82 2wd with 305 electronic spark control and as stock as I've seen, including smog pump and gobs of vacuum line. This could possibly be the first time the valve covers have been off. Before it broke, it was running fine, but did lack some power and ran pretty rich normally, but the idle and mixture seemed pretty inconsistent.
I have been planning on rebuilding the carb for awhile, but haven't gotten around to it. I did however buy and read a book on rebuilding and modifying quadrajets--and realize that I just don't want to do that. Now, I have everything off and am taking a break before I pull the intake manifold. I am doing the intake gasket, valve cover gaskets(they were leaking anyway), valve seals, waterpump, timing set, and was planning on buying a rebuilt quadrajet (theres a local guy that rebuilds em per application who I've heard good things about). So here are my questions:
I do have an edelbrock performer intake manifold laying around that a guy gave me. Should I use that and get a different carb? I feel like I should just keep it as stock as I can since I am going to be selling it though.
If you were in this position would you remove the smog pump stuff, and is it as simple as leaving the pump off, getting a smaller belt, removing all of the extra piping off the exhaust manifold, and capping the holes? What's the likely hood I can do that withouth breaking one of the fittings off in the manifold? How have yall done that? Or would I need headers?
Should I leave the electronic spark control stuff. I don't know alot about it, but seems like its prone to malfunction and a popular modification. I really don't have a good reason to think it wasn't working properly though.
Anything I should know--tips, tricks, anything quirky? What else should I do while I'm here. It is a possiblity that I give it to my parents also, but either way, I would like for it to run tip top.
Thanks for reading, and thanks in advance for the advice.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 02-22-2009, 11:07 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: I'm elbow deep.What should I do while I'm here?
If it ain't broke, don't fix it till it is. Since you are considering selling it, I would fix what needs to be fixed, put the rebuilt carb on it and call it a day...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-22-2009, 11:38 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with N2, No point in kicking the bucket of worms over.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-23-2009, 02:15 PM   #4
Damien
Damien's Avatar
I would just fix what needs to be fixed and send it down the road.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 02-23-2009, 04:12 PM   #5
454HO
X4
Fix the intake and valve cover gaskets and get the original carb rebuilt. No more unless you break something... and hopefully that won't happen.
- Greg
454HO is offline   Reply With Quote
Old 02-23-2009, 04:23 PM   #6
Cherub
Cherub's Avatar
carefull when torqueing everthing down.......
Cherub is offline   Reply With Quote
