Old 02-23-2009, 12:15 AM   #1
67chevtruck
67chevtruck's Avatar
gear ratio difference
what is the largest difference in gear ratios from front to rear that can be used without blowing u joints thanks
67' chevy k10 350 sm420
67chevtruck is offline   Reply With Quote
Old 02-23-2009, 12:48 AM   #2
skchevota
skchevota's Avatar
Re: gear ratio difference
couple of hundredths ( 4.10- 4.11) unless you adjust tire size one each axle like a tractor....
skchevota is offline   Reply With Quote
Old 02-23-2009, 06:33 AM   #3
Yeah,I`ve never seen more than 1/100th off from factory:4.09 front/4.10 rear is common.and,it`s more than u-joints you need to worry about.Anything can break in the middle.
Old 02-23-2009, 02:20 PM   #4
1969K10
1969K10's Avatar
A friend of mines Dakota has 4.10 & 4.11's I believe, and there is a hugh warning not to drive on hard surfaces (paved) in 4WD. If you've got them matched, it won't be an issue.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-23-2009, 08:44 PM   #5
LONGHAIR
I wouldn't run on hard pavement locked in 4 wheel drive, no matter how perfect the gear match might be. It is asking for trouble.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
