Old 02-23-2009, 09:12 AM   #1
renegade6
Shackles popping
I have a 57 pickup with Jeep pickup running gear using the original leaf spring set up. When I'm parked and I turn left or right, I hear a popping sound that is coming from the spring shackles and it looks like springs are shifting within the shackles.
Have any of you had this happen and what did you do to fix it? I'm thinking new shackles, bushings, etc but I'm not sure what will fit the original springs.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 02-23-2009, 11:30 AM   #2
Re: Shackles popping
It could be bad bushings or a broken through bolt.
Old 02-23-2009, 11:32 AM   #3
brew8
It most likely needs bushings, you may also want to check the TRE for play as well, the last thing would be the bearings in the knockle, if you jack it up and the wheel tips in at the bottom you have a bad bearing, if you have open knuckles you may have a bad ball joint, cheers, Larry
brew8 is offline   Reply With Quote
Old 02-23-2009, 01:23 PM   #4
estig70
estig70's Avatar
could be bad ball joints as well. the sound can travel and resonate through the leaf springs and sound like that is where it is coming from. good luck diagnosing and eliminating the problem.
Eric
estig70 is offline   Reply With Quote
Old 02-23-2009, 01:25 PM   #5
renegade6
Thanks everyone. I'm pretty sure it is the shackle, I can see the spring move within the shackle when the wheel is turned.
Anyone upgraded to better shackles on these, or is stock about the best option?
Brandon
Old 02-23-2009, 07:54 PM   #6
brew8
the length and angle of the shackel have more to do with articulation, you may just need to replace the bushings to take the slop out from between the shackel bolt to the mount, Larry
Old 02-23-2009, 08:28 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
That's your problem,The shackles need to be tight against the inner sleeve of the bushings.If it runs very long it may elongate the bolt holes in the shackle or shear the bolts off.......At highway speed that would be ugly
powerdriver 1958 is offline   Reply With Quote
