GOT A ? for you experts!!
My question is does anyone know what gear ratio came stock in a 94 1/2 ton 2wd rear end? Would i have to do any mods to get it to go into my 69 C/10...the lame @$$ who put my rear end in put 4:56's in with my 383 stroker and a TH350
![]() Shane |
Re: GOT A ? for you experts!!
Sounds like you have one mean 1/8 mile truck. On the 94 if it is still readable there is a plate in the glove box that has your vin & a bunch of letter/numbers if you can read them they will identify what gear ratio.(all those digits tell everything about building your truck, like a shopping list) Just have to ask parts man at dealer. To install it is something that is possible but will require welding & fabrication, probably be easier to buy something stronger that fits. Why not buy new gears for the one in it.
true you have a point in just buying the gears...i was just thinking the rear end cause it was being given not sold.....lol
Shane Live life like there isn't going to be a tomorrow.....Because tomorrow doesn't exist! ![]() ![]() |
yeah thought about that but its hard finding one here your not going to get price raped on...lol
Jason
My truck stock came with a 3.07 ratio with TH-350 trans at 70 you will be around 2600 to 2700 rpm with a 28" tall tire. I am in the process of installing a 3.73 rear gear and can let you no about that in a few days.
see that's what i can't figure out at 2000 rpm i'm only at 40 to 45 mph with a 25" tire
If you want suggestion on gears let us know what tires, & where you drive (in town / or mostly on the highway) I agree on 700R4 or 4L60E or even 4L80E but gears are probably still a little steep. Maybe 3.73 + or - a little.
Thanks Rat...i will def. look into the 700r4 option but for the time being i do only drive around town but would like to jump onto the freeway once in awhile and my tire size is 295/50/15
Maybe someone will jump in with other suggestions. I would suggest the 3.73 - to 3.42 gear range and go with the tranny. change later.
thats what i was thinking too...thanks bro
Shane ![]()
Watch out for your cornhole !
![]() Join Date: Jun 2003
In my experience ( I was a GM dealership tech in 94), better than 80 percent of those year trucks had 3.42
Jason
With only a 25" tall tire I would go with the 3.42 ratio.
#13 |
muddobber
i ran your specs on my truck w/ a 373 gear aND ran about 3000 -3200 rpms at 55. sounds like you prolly go through the rear hides pretty often
