Old 02-23-2009, 02:56 PM   #1
whutdidyousay
Help me find a part
I've just ordered my new transmission and the shop won't warranty it unless the kickdown cable is hooked up.
That means I need your help finding a kickdown (detent) cable bracket for an inline 6 250.... all stock for now. I think it's a mid 70's block with the separate head and intake manifold. if someone knows where a supplier has one for sale that would be great!
Thanks!
whutdidyousay is offline   Reply With Quote
Old 02-23-2009, 03:15 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Help me find a part
I would call a local wrecking yard that keeps some older trucks - they should be able to fix you right up.
That kick down cable also helps to control the fluid pressure in the case - important on a T350, critical on 700R4 and other over drive trannys.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-23-2009, 03:37 PM   #3
mrh33916
Project '67 454
mrh33916's Avatar
The shop should be able to sell you a universal kick down cable kit available from thier transmission parts supply house.
mrh33916 is offline   Reply With Quote
Old 02-23-2009, 04:22 PM   #4
cdowns
cdowns's Avatar
try gm dealership//summit jegs//bowtieoverdrives//help section local autoparts store
Old 02-23-2009, 07:31 PM   #5
whutdidyousay
I did find one that I'm bidding on, but we'll see how that goes.
All of the boneyards around here seem to be stripped of anything in the engine bay.
I'll try more of the aftermarket suppliers... so far all of the ones I see are for 4bbl carbs or v-8's
Won't go to the dealer for anything...
Plus I know I can find it used.... I don't need some fancy shiny bracket, just one that does the job.
