Old 02-23-2009, 03:03 PM   #1
bac1755
bac1755's Avatar
speedo gears
I have a TH350 with a 3.73 rear end and 275/60/15 tires (28") in my 71 GMC the problem is I donthave the drive or driven gear for the speedo and can seem to find out what gear combo i need to go with.
Can anyone pointme in the right direction?
bac1755 is offline   Reply With Quote
Old 02-23-2009, 03:22 PM   #2
wHATANERD
wHATANERD's Avatar
Re: speedo gears
This might help:
http://www.tciauto.com/Products/Tech...eedo_gears.asp
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 02-23-2009, 03:30 PM   #3
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Re: speedo gears
It will be the the purple gear with 10 teeth. I just did the same swap on my 350/TH350 with 3.73s.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 02-23-2009, 03:32 PM   #4
westbrookw
westbrookw's Avatar
Re: speedo gears
Actually, let me go to the house and I will look at it. But I am pretty sure that is what I used. The one you pulled out should have been black with 8 teeth on 3.08 gears.
72 SWB/Step
Old 02-23-2009, 03:39 PM   #5
bac1755
bac1755's Avatar
Re: speedo gears
Ok I have a spare purple gear for the trans do you know what gear you used for the speedo cable?
Old 02-23-2009, 05:18 PM   #6
westbrookw
westbrookw's Avatar
Re: speedo gears
The driven gear I took out of the speedo sender was an 18 tooth gear, I believe the color was supposed to be purple. A friend of mine and I did alot of research and found that I need a 22 tooth driven gear. The drive gear inside of my trans is the 8 tooth orange gear. Here is where we found real good info. http://www.tciauto.com/Products/Tech...eedo_gears.asp. That is all I have. I have no idea as to weather mine is accurate due to the fact I have my speedo cable in the mail. That should get you close by our calculations.
72 SWB/Step
Old 02-24-2009, 02:43 AM   #7
bac1755
bac1755's Avatar
Re: speedo gears
thanks for the help i'll check it out.
Old 03-06-2009, 09:07 AM   #8
westbrookw
westbrookw's Avatar
Re: speedo gears
It is pretty accurate. I was rolling at 55 with a buddy beside me telling me he was at 55. We ran them all the way up to 70 reading the same. I guess this would have to be your combo. Good luck. Glad I could help you in anyway.
72 SWB/Step
Old 03-06-2009, 10:16 AM   #9
wHATANERD
wHATANERD's Avatar
Re: speedo gears
Glad to hear you got it figured out.
