Old 02-23-2009, 06:22 PM   #1
au03z71
au03z71's Avatar
Best place to mount air tank.
I have a 3 gallon air tank (10"-12" in diameter) that I need to mount somewhere on my 72'. I am planning on mounting a blazer fuel tank between the rails under my bed. Where could I fit my air tank? Is there a preferred spot? If anyone has pics of their setup I'd appreciate it.
au03z71 is offline   Reply With Quote
Old 02-23-2009, 06:49 PM   #2
leftcoast66
leftcoast66's Avatar
Re: Best place to mount air tank.
Mine's just bolted under the bed on the drivers side mounted against the outside of the frame rail. Then I've got the compressor just under the cab on the drivers side so they are right next to each other. No pics though, and I'm planning to backhalf the truck soon so they got moved. Most likely will put them right under the bed on each side of the driveshaft. Sorry no pics, but that's my setup and my plan for redoing it.
leftcoast66 is offline   Reply With Quote
Old 02-23-2009, 11:06 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The problem is the diameter of your tank, it is rather a large diameter. I have a tank that is only about 8" diameter, and about 26" long and fits under the bed along the framerail on drivers side like Leftcoast66. I am going to install the Blazer tank as well, where the spare would go.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-25-2009, 04:26 PM   #4
au03z71
au03z71's Avatar
That's where I plan to mount my Blazer tank. I will check the diameter of my air tank and see the exact diameter. Maybe it's 8", but it seems like it's bigger...
Old 02-25-2009, 05:22 PM   #5
sick69
sick69's Avatar
Seems alot of people are mounting their air tanks behind the rear wheel on the outside of the frame rail,,,,,,,
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 02-25-2009, 10:41 PM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Frank
I might have done that too, but when you have a GMC then you have leaf spring hangers in the way.
Old 02-26-2009, 12:27 AM   #7
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i mounted mine behind the rear wheel on the outside of the frame. by the sounds of it, i have the same tank as you.
IvelDesigns is offline   Reply With Quote
Old 02-26-2009, 07:42 AM   #8
au03z71
au03z71's Avatar
Tha is the same tank as mine. Did you have any bed clearance issues?
